Fail safe way to update ANX7688 firmware
i guess you'll need to have root privileges and make sure your kernel is below version 5.10.
Just added the sudo command to the first post.
BTW, the PMOS factory test image uses kernel 5.7 and everything was nice.
Good luck!
Cheers,
scholbert
RE: Fail safe way to update ANX7688 firmware - by scholbert - 02-09-2021, 04:11 PM
  firmware udate Quectel EG25-G modem alwi 7 5,103 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,650 07-06-2022, 12:35 PM
  camera firmware problems kqlnut 25 20,877 09-02-2021, 07:49 PM
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 1,678 06-22-2021, 10:03 AM
  WIFI not available after anx7688 update failure frimmel 21 18,896 05-11-2021, 02:45 AM
Last Post: frimmel
  Pinephone mainboard v1.2 documentation update? scholbert 1 2,567 01-18-2021, 09:01 PM
Last Post: bokomaru
  New motherboard - ANX firmware won't flash. --- 17 12,768 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Update to 3GB/32GB mainboard not working tlo 2 3,610 11-09-2020, 04:40 PM
Last Post: tlo
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 3,420 10-04-2020, 11:18 PM
Last Post: Vlodka
