Fail safe way to update ANX7688 firmware
as there'd been a lot of reports of failed updates for ANX7688 firmware, i thought i'd share my experience here.
The wiki already points out that there's some trouble with Linux kernel 5.10 (timeout)
and i had some trouble with the image it refers to... here's a fail safe way!
Before (version 0x2312):
[  11.356306] anx7688 1-0028: fw loaded after 40 ms
[  11.365598] anx7688 1-0028: OCM firmware loaded (version 0x2312)
[  11.380796] anx7688 1-0028: send pd packet cmd=0 05 00 32 90 01 26 12
[  11.405217] anx7688 1-0028: send pd packet cmd=1 05 01 2c 91 01 26 16
[  11.405764] anx7688 1-0028: send pd packet cmd=2 11 02 00 00 00 ec 00 00 00 00 00 00 00 00 39 00 00 51 77
[  11.406629] anx7688 1-0028: send pd packet cmd=3 05 03 00 00 01 ff f8
[  11.407149] anx7688 1-0028: OCM configuration completed
[  11.409664] anx7688 1-0028: status changed to 0x00
To upgrade safely, download PMOS factory test image:
https://images.postmarketos.org/pinephon...t64.img.xz
Write image to SD-card...
Put the SD-card into linux host and mount PM_root.
Replace /lib/firmware/anx7688-fw.bin with the latest one from:
!!!Attention!!!
Before using the serial debug cable, please disable headphone with the kill switch.
Insert card to your Pinephone and use serial debug cable (most convenient way):
login: demo
pwd: demo
...then:
sudo -s
Kernel messages will inform you about the eeprom flash process afterwards (call dmesg).
Send the device to halt and remove the SD-card.
Then after booting up to your OS will give:
[  184.219123] anx7688 1-0028: eeprom0 = 0x03
[  184.219145] anx7688 1-0028: fw loaded after 40 ms
[  184.219319] anx7688 1-0028: OCM firmware loaded (version 0x2410)
[  184.220257] anx7688 1-0028: send pd packet cmd=0x00 05 00 32 90 01 26 12
[  184.264040] anx7688 1-0028: send pd packet cmd=0x01 05 01 2c 91 01 26 16
[  184.264557] anx7688 1-0028: send pd packet cmd=0x02 11 02 00 00 00 ec 00 00 00 00 00 00 00 00 39 00 00 51 77
[  184.265367] anx7688 1-0028: send pd packet cmd=0x03 05 03 00 00 01 ff f8
[  184.265871] anx7688 1-0028: OCM configuration completed
[  184.269329] anx7688 1-0028: status changed to 0x00
That's it! Successfully upgraded to OCM firmware version 0x2410.
Hope this helps to avoid further confusion.
Cheers,
scholbert
Fail safe way to update ANX7688 firmware - by scholbert - 02-05-2021, 10:17 AM
  firmware udate Quectel EG25-G modem alwi 7 12,502 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 6,650 07-06-2022, 12:35 PM
  camera firmware problems kqlnut 25 36,500 09-02-2021, 07:49 PM
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 2,829 06-22-2021, 10:03 AM
  WIFI not available after anx7688 update failure frimmel 21 31,089 05-11-2021, 02:45 AM
Last Post: frimmel
  Pinephone mainboard v1.2 documentation update? scholbert 1 4,168 01-18-2021, 09:01 PM
Last Post: bokomaru
  New motherboard - ANX firmware won't flash. --- 17 22,410 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Update to 3GB/32GB mainboard not working tlo 2 5,728 11-09-2020, 04:40 PM
Last Post: tlo
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 5,805 10-04-2020, 11:18 PM
Last Post: Vlodka
