Extremely fast pmOS build for the pinephone
Wink
Hi folks!
You might think your pinephone is a slow POC device.
Welp! that's true BUT pmOS sxmo is an incredibly smooth OS!
You can check my review here: https://youtu.be/Q6L9K0EW3qg
*How to install?*
# 1. Easy way --
## 1.1 From the computer
Download https://lucasanss.xyz/pine64-pinephone.img
then burn the image to you sdcard*.
On a linux desktop the fastest way to do so is to download
the image while uncompressing it while writting the decompressed
output on your device.
if your sdcard is `/dev/mmcblk0` run:
`curl https://lucasanss.xyz/pine64-pinephone.img.zst | zstdcat > /dev/mmcblk0`
if you want to check the writting progress:
`curl https://lucasanss.xyz/pine64-pinephone.img.zst | zstdcat | dd of=/dev/mmcblk0 status=progress`
Then boot
## 1.2 From your phone
- Boot from your internal storage, /!\ -- important!
- Open up a terminal, run**:
  `sudo su`
  `curl https://lucasanss.xyz/pine64-pinephone.img > /dev/mmcblk0`
  /dev/mmcblk0 is the default partition for your external sdcard.
## 1.1 credentials
Default login : pine
Default password: enip
# 2. The hard way
Read the wiki https://wiki.postmarketos.org/wiki/PINE6...pinephone)
Follow the `pmbootstrap` instructions.
# 3. Important notes
READ the user instructions: https://git.sr.ht/~mil/sxmo-docs/tree/ma...ERGUIDE.md
Sxmo is easy to use but there is a certain learning curve.
For example by default the modem is disabled. While you'll
be able to make phone calls and receive sms, you'll can't
receive any. So you'll need to enable it via the menu.
* If you use windows, I'd suggest using `rufus` in dd mode, or etcher.
Nonetheless, I haven't tested burning the image on windows
** Make sure curl is installed and that you have a reliable internet.
If download fails restart. Otherwise download the image and flash it
with `wget` and `dd`:
`wget https://lucasanss.xyz/pine64-pinephone.img`
if download succedeed:
`sudo dd < pine64-pinephone.img > /dev/mmcblk0`
yes you can use “<” and “>” instead of “if=” and “of=”
Extremely fast pmOS build for the pinephone - by lucasanss - 02-03-2021, 04:05 PM
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 1,976 11-18-2024, 02:23 AM
Last Post: linmob
  Fresh install pmos+phosh does not boot user641 1 1,147 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 4,528 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Boots To Shell After Dead Battery (PMOS) britelite 0 1,098 02-17-2023, 02:41 PM
Last Post: britelite
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 1,967 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,989 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  No Application Data PMOS 21.12.1 Captain1ndustry 4 4,955 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 7,730 07-10-2022, 03:26 AM
Last Post: arkadione
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 3,418 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 4,041 06-20-2022, 01:33 PM
Last Post: elof
