GPS is broken! Change wiki and page! And where is the antenna ?
Hardware worked fine with my Brave Heart last time I tried it. Performance was similar to other smartphones when using the AGPS data loader, but first fix was unreliable without AGPS. This is also true of most smartphones if you can force them not to use AGPS - a decent GPS antenna is even bigger than the headphone sockets many manufacturers think take up too much room. For most people the problem is that AGPS isn't used by any of the distros yet so it's not easy to use, much like the current state of MMS support. The mobian wiki has a fair amount of detail: https://wiki.mobian-project.org/doku.php?id=location
The number of people with a hardware fault seems to be small so far - at least I only remember one or two. That's not great but not (yet) an indicator of a wider problem.
You can find the antenna via the schematic and the component layout docs - IIRC it's the printed antenna on the top corner by the camera bump, with spring terminal connections on the main board. I don't think it has a connector that you could easily attach a different antenna to.
I hadn't realised this wasn't in the Pine64 wiki - I'll see about adding something. You should be able to edit the wiki using the same credentials as the forum, although I gather this broke for a bit so you may need to contact an admin if it doesn't work for you.
RE: GPS is broken! Change wiki and page! And where is the antenna ? - by wibble - 02-03-2021, 07:08 AM
  Jumpdrive broken? eMMc broken Uturn 5 1,604 04-21-2023, 12:37 AM
Last Post: Uturn
  UI crashes after unplugging USB device, seen on multiple OSes; is my hardware broken? slondr 1 904 11-05-2022, 11:31 AM
Last Post: slondr
  list of linux native apps/softwares for pinephone on the wiki alexandre 7 7,166 10-26-2021, 11:56 PM
Last Post: bcnaz
  my broken pinephone, possible sale zetabeta 4 3,291 09-28-2021, 11:09 AM
Last Post: fervi
  PmOS Phosh: set compose and change layout stozi 3 2,383 09-24-2021, 07:41 AM
Last Post: ryo
  How to use Pinephone as wifi antenna for Pinebook Pro stozi 3 2,506 08-26-2021, 05:05 AM
Last Post: wibble
Photo Page allocation failure on KDE Community edition -"0 pages hwpoisoned" countcitrus 1 1,819 02-20-2021, 06:16 PM
  How to reinstall a broken OS on Pinephone's internal storage? danimations 1 2,894 01-24-2021, 10:14 PM
Last Post: danimations
  Contribute tu Pine64 wiki p1trson 3 2,897 11-24-2020, 05:12 AM
Last Post: evilbunny
  suggestion the broken screen issues dallytaur 0 1,417 11-19-2020, 10:27 PM
Last Post: dallytaur
