Battery Charge Status not reporting correctly? (KDE Community Edition)
(02-12-2021, 12:12 PM)Gregorius Techneticies Wrote: Hrrm I once read that you should remove the Battery before removing the SD Card, did you do that? (I know for sure, I violated that Rule at least twice, and stuff still works)
Are there ways other than Jumpdrive or a pre-existing OS to flash the eMMC? Maybe something along those lines could help you if the built in SD Card Reader is faulty.
And super dumb Questions:
You did put the SD Card into the upper SD Card Slot and not the lower SIM Card Slot, right?
Also you didn't umop-apisdn anything either, right?
I don't think I have any more Ideas to help you. I'm new to this just like you. I just happen to know a bit about Development and Support from unrelated Projects. XD
Yes, I've removed the battery every time. It's in the upper slot, my sim is in the bottom. I had to look up "umop-apisdn" but no that is not the case. I don't know of anything else to flash the emmc at this moment without using an SD card. The only reply I have on my post says hardware failure Sad I know people were just going to assume I'm doing something wrong but this isn't the case... I will contact support soon if no one can seem to help me. Thanks again and hope you have good luck with your phone!
RE: Battery Charge Status not reporting correctly? (KDE Community Edition) - by Giddyup - 02-12-2021, 12:18 PM
  Best Battery Life luney 2 3,237 05-06-2025, 07:36 AM
Last Post: mikehenson
  8/24 status of JumpDrive shengchieh 3 1,955 12-05-2024, 12:13 PM
Last Post: zetabeta
  Increasing battery life slondr 8 10,381 03-19-2024, 02:15 PM
Last Post: aular
Bug Wrong Battery Charge Level Displayed - How to Fix acid andy 7 9,991 06-12-2023, 01:04 PM
Last Post: jakfish
  Genode OS Now Live (finally a battery friendly PP OS?) PineFone 0 2,458 02-04-2023, 09:38 AM
Last Post: PineFone
  Pine phone Battery life vs operating system bcnaz 19 29,368 08-27-2021, 09:35 PM
Last Post: bcnaz
  Beta Convergence edition external display? Ferenc 3 4,350 07-28-2021, 11:50 AM
Last Post: Ferenc
  KDE community edition, first feedback Goffi 2 4,528 02-08-2021, 02:42 PM
Last Post: treebuilder
  Nav buttons and status drawer no longer visible (KDE Community Edition) heatsink 6 10,129 02-04-2021, 06:09 PM
Last Post: bshah
  Battery life for various OS & UI lat 8 14,678 12-21-2020, 08:20 PM
Last Post: ryo
