Mobian PIN changed after update!
I'm running into a similar problem, but the pin is getting changed while I'm doing an apt update, not using the Software application. I did try to update via ssh, but found the connection dropped and I couldn't get back in. Updates from KingsCross were faster, it seemed, but once the screen locked, well, you know the rest.
There does seem to be a GitLab issue with Mobian:
https://gitlab.com/mobian1/issues/-/issues/174
I'll be trying some of these suggestions once I have time, will report back if anything of use comes of it.
Mobian PIN changed after update! - by Mwo87 - 01-29-2021, 08:59 PM
RE: Mobian PIN changed after update! - by Mwo87 - 01-29-2021, 10:28 PM
RE: Mobian PIN changed after update! - by Mwo87 - 01-30-2021, 10:50 AM
RE: Mobian PIN changed after update! - by signal9 - 02-03-2021, 10:53 AM
RE: Mobian PIN changed after update! - by Mwo87 - 02-04-2021, 10:44 AM
RE: Mobian PIN changed after update! - by Mwo87 - 02-04-2021, 04:28 PM
RE: Mobian PIN changed after update! - by dawg161 - 02-05-2021, 07:59 PM
RE: Mobian PIN changed after update! - by Mwo87 - 02-07-2021, 12:29 PM
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 3,521 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No longer waking up from sleep after recent update gamerminstrel 2 822 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  No sound after Mobian upgrade arbocenc 1 470 11-28-2022, 11:02 AM
Last Post: arbocenc
  no sdcard boot and manjaro update failed Gwen 3 848 11-27-2022, 07:56 AM
Last Post: fxc
Exclamation No wIfI after Mobian update crakabeats 3 1,566 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 1,691 09-24-2022, 08:01 AM
Last Post: dante404
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 6 5,192 06-11-2022, 06:40 AM
Last Post: Peter Gamma
  update kills keyboard ludgate 1 855 05-18-2022, 12:43 AM
Last Post: programmin
  PinePhone running Mobian - Malware extraction? names_fold 1 1,306 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 1,664 01-17-2022, 02:18 AM
Last Post: bcnaz
