Midnight Commander on Mobian
Hi everyone,
Just thought I would share my experiences with trying Midnight Commander on Mobian:
(It is a terminal-based twin pane filemanager)
I installed it from Kings Cross by:
sudo apt install mc
I then ran it from Kings Cross by typing:
mc
it seemed to run fairly well, and also worked with touch input.
It has many functions built-in, such as an editor, working with permissions and file-ownership etc.
(Note: It also seemed to add 2 new icons to the desktop, which did not seem to do anything?)
Some tricks I have found useful are:
It seems to be able to be run from sudo for special reasons, perhaps to delete files owned by root etc.
Choosing to  zoom in/out from the terminal it is running in can make more room on the screen to see filename etc.
choosing to display the twin panes one on top of the other instead of side by side is helpful for reading long filenames (I was able to change it via a menu option)
Sometimes the phone needs to be changed to landscape mode for a few seconds to see an option.
Pressing F10 should exit the program, and return to the terminal.
(F10 should be accessible from the on screen keyboard, by pressing second key from left at bottom, then enabling "terminal" mode, then pressing the second key from right at bottom (marked   >_  ).
Hope this is interesting to someone! -regards.
Midnight Commander on Mobian - by rp3 - 01-19-2021, 05:43 AM
RE: Midnight Commander on Mobian - by scholbert - 01-20-2021, 09:49 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,514 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 70 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,711 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,687 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 580 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,540 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,798 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 577 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 2,861 06-19-2023, 03:02 PM
Last Post: vusra
  Axolotl on PinePhone / Mobian arno_nuehm 219 160,120 03-26-2023, 01:49 AM
Last Post: shulamy
