HELP: PBP screen blanked
What *have* you done so far?
You did a November update to Manjaro.
Did you reflash the eMMC?
Did you try to boot from micro SD?
I don't have experience with this problem, but it seems to be widely reported that a Manjaro update can cause your symptom, and that the U-Boot that comes with Manjaro can disallow booting from micro SD.
Have you read any of the other threads here about this?
What I expect is that you'll need to put a bootable image on a micro SD card, disable the eMMC by hardware switch, boot to said SD card, and reflash the eMMC.
HELP: PBP screen blanked - by iscmob - 01-16-2021, 07:31 AM
RE: HELP: PBP screen blanked - by KC9UDX - 01-16-2021, 08:21 AM
RE: HELP: PBP screen blanked - by iscmob - 01-17-2021, 09:28 AM
RE: HELP: PBP screen blanked - by KC9UDX - 01-17-2021, 11:10 AM
RE: HELP: PBP screen blanked - by iscmob - 01-19-2021, 08:43 AM
RE: HELP: PBP screen blanked - by KC9UDX - 01-19-2021, 10:00 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 289 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 2,944 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,002 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 1,980 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,082 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,736 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 4,733 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Screen refresh delay with kernel errors shawnanastasio 31 38,608 04-27-2021, 02:57 AM
Last Post: james64
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 19,564 01-27-2021, 10:48 PM
Last Post: rimaille
  Screen flicker with USB-C charging bchenlee609 5 5,843 01-25-2021, 08:48 PM
Last Post: bchenlee609
