Anyone know how to start a terminal at current dir with Nemo?
(01-14-2021, 05:40 AM)rp3 Wrote: Hi, I'm just using the default filemanager included with mobian, and I often would want to quickly start a terminal in the folder I am currently in.
I can find some options which should work, but no luck so far. I have enabled an icon on the taskbar of nemo which should start a terminal, but nothing happens.
In browsing the web, I found reference to this in regard to enabling a terminal in nemo, but I don't know how it would apply to mobian:
gsettings set org.cinnamon.desktop.default-applications.terminal exec <terminal-name>
I also found reference to "nemo-terminal", but I don't know how to install it (or if I should).
Can anyone help me with this?
Regards to all!
Thing is, mobian uses kingscross by default. Have ou tried sudo apt install nemo-terminal in kingscross you can check what apt does before it installs.
RE: Anyone know how to start a terminal at current dir with Nemo? - by sfb - 01-18-2021, 10:20 AM
  USB current limit fernando_c_m 12 21,273 10-08-2025, 10:49 AM
  New Install, apps start but don't show up on screen?! RT3 2 1,798 07-18-2025, 07:56 PM
  Errors when start the system kubussz 2 2,618 11-21-2023, 11:07 AM
Last Post: kubussz
  Auto start application on Phosh login Zebulon Walton 8 9,037 10-14-2023, 06:29 AM
Last Post: alaraajavamma
Sad Chatty can no longer start since the last update anonymous 10 10,163 06-08-2022, 01:03 PM
Last Post: Korac
  Issues with Mobian? Start here. tophneal 0 8,144 04-21-2022, 11:27 AM
  Reading SMS from the terminal? SocialNetworkingWasAMistake 6 7,461 10-19-2021, 10:01 AM
Last Post: ragreenburg
  after dist-upgrade, terminal is broken nelstomlinson 9 9,579 09-09-2021, 06:47 AM
Last Post: nelstomlinson
  (Gnome) Maps won't start on Mobian? TRS-80 3 5,101 07-11-2021, 12:09 PM
Last Post: TRS-80
  How do you copy and paste into mobian terminal? Do you ssh instead? temp0rary 6 8,798 06-01-2021, 12:16 PM
Last Post: temp0rary
