Replaced USB-C side board, touch screen goes nuts
(01-10-2021, 04:09 PM)Zebulon Walton Wrote: Update:  It appears the problem was caused by a new charger that I was using. I've been using a generic 2A USB charger from eBay that worked perfectly. So I ordered another one as a spare, and that came in the same time as my USB side board. So I didn't give a thought to powering the phone up with the new charger after installing the new side board. (I normally have the phone plugged into the mains when using it at home.)
Turns out that if I use the old charger or just run off the battery that the phone works fine. So the new charger is either off voltage or sending some kind of disruptive signal or spikes into the phone and making it go crazy.
As far as the buzzer problem I'm not sure why that didn't work when the new USB board was installed. Of course the wiring is fragile but as far as I can see nothing was damaged. It maybe be related to the same problem, so when I get a chance I'll try reinstalling the new board.
Figure anything out on this one?
RE: Replaced USB-C side board, touch screen goes nuts - by israel - 04-14-2021, 09:50 AM
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 354 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,274 10-12-2023, 01:03 PM
Last Post: robthebold
  Pine phone main board part Generaltuxenburg 1 1,021 07-31-2023, 07:50 PM
  Screen dying already? marcih 153 143,648 02-23-2023, 04:14 AM
Last Post: Shatur
  USB C side board out of stock gab 3 1,836 12-29-2022, 11:42 AM
Last Post: fxc
  What Adhesive to buy for daughter board? LogosCoder 1 1,008 11-28-2022, 05:07 PM
  Screen Replacement Instructions erikkugel 4 3,088 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,581 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,706 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 3,976 03-08-2022, 12:25 PM
Last Post: jopple
