Does mobian use a root account and password?
(04-01-2022, 09:58 AM)parry Wrote:
(01-10-2021, 05:35 AM)ryo Wrote:
(01-10-2021, 04:07 AM)rp3 Wrote: ryo, thanks for tip about password, this is interesting.
I am wondering if I change the password from a numeric pin if I will have trouble unlocking the phone when presented with the number pad? -or will this still be the old numeric pin, independent of the new alphanumeric password? -Thanks
If you mean changing for the Mobian user, then yes.
You will be locked out from the GUI, so I do hope you have SSH enabled before you even try this out, or you'll need to re-flash your phone as your only way out.
You must change it to a password consisting of numbers only in order to be able to unlock the screen.
If you mean changing for the root user, then that will have no meaning regarding ability of logging into your phone.
For me the question is how to change the default pin.  The only place I can find to do that through the UI is under Users (in Mobian). However as much as I can change the 1st entry with a new password,  the system wont allow me to enter a confirming string. I understand that I can change the pin through the comand line using passwd, but why can't I change the pin through the UI ?  In fact changing the password with passwd does not change the login pin.  This is rather frustrating.  And inane
Thanks for any replies
OK, let me reply. It is rather idiotic, but going to the Users section of the Settings app although completely intuitive, does not work.  Really??? Yes really. Instead, starting a terminal session and using the usual linux command passwd takes care of the problem.  Not even sudo passwd -  which does not retain the change.  I wonder where I missed the documentation for this. Duhhhhhh
OK, let me reply. It is rather idiotic, but going to the Users section of the Settings app although completely intuitive, does not work.  Really??? Yes really. Instead, starting a terminal session and using the usual linux command passwd takes care of the problem.  Not even sudo passwd -  which says the password has changed does not retain the change.  I wonder where I missed the documentation for this. Duhhhhhh.
RE: Does mobian use a root account and password? - by parry - 04-04-2022, 07:26 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 49,864 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 35 63,349 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 30,664 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 0 2,411 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 295,091 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,184 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,879 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,400 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,286 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,412 01-15-2025, 08:08 PM
