(01-07-2021, 06:03 PM)tgz Wrote: OK was going to mess around some more trying to update but all I can get now is flashing red light, which I believe is kernel panic. So, starting to research the flashing procedure (flashing of OS, not the light ), can see right off I may need some hardware accessories. Looking forward to getting this running!
Edit/update: just wanted to post this for any other noobs passing through, checking out threads of interest on Reddit and saw a bunch of comments with general consensus seemed to be to not even bother with the shipped OS (trying to update it), just go right to flashing a fresh install.
https://www.reddit.com/r/pinephone/comme..._failures/
still have to get some accessories together to proceed, doing some research...
I just flashed the newest release Beta 20. I tried to update with pacman and received an error:
error: pinephone-manjaro-tweaks: signature from "Phillip Mueller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pinephone-manjaro-tweaks-20211220-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it?
I typed the above in by keyboard (sorry if there is a spelling error).
I did delete that file, started over, and received the same error. I never tried "n" in answer to that question. I tried using the Add/Remove Software GUI. It wanted to update pinephone-manjaro-tweaks-20211220-1. I proceeded and received this error:
invalid or corrupted package (PGP signature):
I tried the advice above in the previous posts and forced an upgrade, but no luck. I tried sudo pacman-key --init, sudo pacman -S manjaro-keyring, sudo pacman -Syyu, and sudo pacman-mirrors -c <"Placed my country here.">.
I'm very new to Manjaro. Is there a fix for this?
(12-22-2021, 03:11 PM)tk1107 Wrote:(01-07-2021, 06:03 PM)tgz Wrote: OK was going to mess around some more trying to update but all I can get now is flashing red light, which I believe is kernel panic. So, starting to research the flashing procedure (flashing of OS, not the light ), can see right off I may need some hardware accessories. Looking forward to getting this running!
I powered down the phone and started it back up. I tried "sudo pacman -Syyu" again and it updated fine. I typed "sudo pacman -Syyu" again to make sure. There were no issues and it indicated that "there was nothing to do" so it updated fine. I went back to the Add/Remove Software GUI and tried to update. It said that the software was up to date.
My problem seems fixed now.
