January image
(01-02-2021, 06:43 AM)defactofactotum Wrote: New image has crust power management enabled - this can sometimes entail the device not waking up at all. Battery performance appears much better....over 24 hrs with little use.
Calls still extremely problematic, camera still non-functional. SMS works, sometimes, a reboot gets it back.
Apart from that, everything else appears very smooth on the emmc, noticeably slower on sdcard.
Bluetooth appears to work. MTP and Sailfish Connect (KDE connect) work fine. Patchmanager still doesn't work.
This version has no first-run problems and doesn't seem to have the old security pin bug...it's probably still safer to turn it off after completing the initialization.
Does this image have the issue of getting hung at the lock screen? Or is that what you meant by old security pin bug? Because that is super annoying. Sailfish is easily the OS I want most for the PinePhone so hopefully this all comes together sooner rather than later.
January image - by defactofactotum - 01-02-2021, 06:43 AM
RE: January image - by ragreenburg - 01-04-2021, 10:03 AM
RE: January image - by defactofactotum - 01-04-2021, 02:30 PM
RE: January image - by ragreenburg - 01-05-2021, 04:06 PM
RE: January image - by defactofactotum - 01-07-2021, 06:34 AM
RE: January image - by ragreenburg - 01-07-2021, 09:58 AM
RE: January image - by DrPhibes - 01-07-2021, 01:43 PM
RE: January image - by Csanderson0313 - 01-08-2021, 03:53 PM
RE: January image - by DrPhibes - 01-08-2021, 10:27 PM
  RAW image output only 32MB and not working Kimberley van Buyten 3 2,182 05-30-2022, 08:00 AM
Last Post: acrux
  flash-it.sh script currently unable to create a SailfishOS image acrux 3 3,797 07-23-2021, 01:06 AM
Last Post: OhneZ
  February image, upgrade to SFOS4 defactofactotum 8 8,227 02-24-2021, 09:45 AM
Last Post: defactofactotum
  December image defactofactotum 3 5,292 12-16-2020, 05:35 AM
  Fresh image, SIM card working RodneyMyers 22 23,434 09-23-2020, 08:53 AM
Last Post: sfb
