Blinking red light for charger, no power-on
(01-01-2021, 01:20 PM)bifo Wrote: It appears that leaving it plugged in with a different charger with USB-C got it to finally accept a charge.  Doing a bit more research the low battery issue may have been caused in part because I'm running Manjaro with a 5.9 kernel and there appears to have been some issue with charging causing the blinking light problem.  Comments I've read say the issue appears after 5.7 kernel versions.
I really don't see how any changes to the Linux kernel could actually affect the PineBook Pro's battery charging, at least not if you use the barrel connector as the power input.  The battery charger IC inside the PineBook Pro is pretty much "dumb" and has no communication with the rest of the laptop or the operating system.  The only way of communicating its status is through the red LED next to the charger connector.
The Type-C power input is a little bit different.  Its separate control IC could be programmed to use different voltage modes offered by the Type-C chargers, but that would also require some hardware modifications to the power path inside the laptop.  However, the same above-described "dumb" charger IC is still used to actually charge the laptop battery.  Reprograming the Type-C control IC without the necessary hardware modifications would cause damage to the laptop.
AFAIK, nobody has made the above-described hardware modifications yet, so currently no changes to the Linux kernel can have any effects to the actual battery charging, no matter which power input is used.
RE: Blinking red light for charger, no power-on - by dsimic - 01-07-2021, 07:31 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 233 03-13-2024, 10:46 AM
Last Post: u974615
  red charge light goes out gilwood 19 1,008 02-10-2024, 10:28 AM
Last Post: gilwood
  No start button light gilwood 6 386 02-09-2024, 08:31 AM
Last Post: gilwood
  Sanity check on spliced charger jcun4128 12 2,607 05-10-2023, 05:23 AM
  PBP solid orange light and does not start Disjoin8272 1 1,015 02-18-2023, 02:46 AM
  Increasing the maximum power draw dsimic 15 19,156 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,618 11-13-2022, 06:10 PM
Last Post: pineymousepad
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,764 10-21-2022, 07:57 AM
Last Post: dachalife
  PBP booting but stops at flashing power led jonasd 13 5,137 09-26-2022, 12:17 AM
Last Post: jonasd
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 1,687 03-23-2022, 12:10 AM
Last Post: wangyukunshan
