Why the 12/15/2020 build is no where near a daily driver yet
(12-28-2020, 04:50 PM)TheLastDon Wrote: Interesting that you have a different experience. I'm going to try the Dec 13th version and see if I notice a difference. The Firefox ESR browser is definitely not snappy for me and I am unable to update anything unless I use the terminal. Thanks for the info.
You're welcome! Just to be sure,  I checked in my book and found that my last fresh install was the 11/6/20 Nightly.  I've been  updating via the terminal since then. Also, are you using the Firefox ESR with wifi? I use mine mostly with my mobile 4G data.  I will try tomorrow with the wifi at work to see if there's any difference.
An issue that may or may not affect you: I'm still having to check to be sure that someone hadn't sent me a mms, which if  there were too many,(I don't get notified and it doesn't  show who it's from) the modem gets jammed  up and cannot receive new  ones.  This is a Chatty limitation. You can only imagine the blame game before i  found out by chance that T-Mobile just so happened to be also having some sms  problems where one can send but not receive.  I understand very well the  feeling of  not knowing what you may have missed. For a while i would send myself text to make sure both ways are working. Anyhow, now that sms are quite reliable, i just check on mms by issuing  sudo mmcli -L  to find out what the modem number is and go from there to check. It could get tedious, but most of my friends now know better than to send me a picture via mms.
RE: Why the 12/15/2020 build is no where near a daily driver yet - by HLing - 12-28-2020, 07:49 PM
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 4,409 07-18-2023, 08:54 AM
Last Post: junelung
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 5,760 09-27-2022, 08:41 AM
Last Post: Katsujinken
  How to check which mobian build I am running jojuma 0 1,466 08-29-2022, 04:44 AM
Last Post: jojuma
  2020-11-13 Image status. Gribouille 45 55,073 11-14-2021, 12:44 AM
Last Post: Gribouille
  I built a reminder app but can't seem to build a deb/snap/flatpak for it, help? ragreenburg 9 11,768 09-10-2021, 02:51 PM
Last Post: ragreenburg
  lima driver issue albertz 0 2,208 02-08-2021, 07:03 AM
Last Post: albertz
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 6,117 01-17-2021, 12:44 PM
Last Post: LibrePhoneUser
  Status update 2020-12-15 a-wai 33 53,427 01-13-2021, 07:14 AM
Last Post: scott_VYuCAbn3k1NFK
  My Daily QA - 2020-10-06 AmazingNutria 6 10,236 01-05-2021, 10:08 PM
Last Post: daniel
  Latest build, cant use top menu Cree 0 2,115 12-26-2020, 07:40 PM
Last Post: Cree
