"Unable to download updates: The following packages have unmet dependencies:"
Just for clearance sake: apt-get or just apt if you prefer the apt, can handle such situations.
If you do just
[sudo] apt upgrade
it is only upgrading already installed packages. if some have new dependencies you can install them using
[sudo] apt-get upgrade --with-new-pkgs
or with
[sudo] apt-get dist-upgrade
. the exclamation around "sudo" means that this is only needed if you aren't root.
RE: "Unable to download updates: The following packages have unmet dependencies:" - by cybercow - 03-03-2021, 09:15 AM
  PureMaps and OSM Scout Server maps download biketool 7 7,284 10-04-2024, 04:25 AM
Last Post: vusra
  Unable to wake up from suspend xavi92 6 5,279 07-28-2024, 02:48 PM
Last Post: dchang0
  packages held back user641 7 5,506 09-18-2023, 03:05 PM
Last Post: diederik
  No volume control after latest updates Zebulon Walton 19 15,644 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 11,813 08-31-2023, 12:38 PM
Last Post: vusra
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 2,993 07-07-2023, 03:29 AM
Last Post: jojuma
  Haven't seen updates in a while Zebulon Walton 3 3,694 06-24-2023, 04:29 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 18,834 10-14-2022, 05:38 PM
Last Post: Krafter
  Wifi issue since last update and held back updates goku499 11 11,919 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Unable to send messages with chatty user641 0 1,693 09-07-2022, 04:35 AM
Last Post: user641
