No internet access through Pinephone hot spot
(12-23-2020, 03:40 PM)dukla2000 Wrote:
(12-23-2020, 08:48 AM)Zebulon Walton Wrote: I decided to try out the wifi hot spot feature since that looks like something that could be useful. Out of the box, the "Turn on Wi-Fi Hotspot" 3 dots menu item in Settings/Wi-Fi is greyed out. So I set it up via command line per the Mobian wiki :
If you start with a fresh Mobian install then I suspect it should work out of the box. You have to enable WiFi first, then the "Turn on WiFi Hotspot" option will be available in the hamburger menu.
The reason I say "suspect/should" is I use USB or ethernet tethering. For sure USB tethering does indeed work out of the box on Mobian, ethernet tethering needs a tweak that can be done via the nmtui user interface. I have a multi-port USB-C dongle that includes an RJ45 socket: plug it all in then go into nmtui, edit the wired connection and change the IPv4 configuration to "Shared" (from Automatic). (In the early days this sharing was also required for USB; in fact I suspect it may be what is missing from your connection and a quick nmtui may fix things?)
Thanks, I'll have to give a fresh installation a try from a bootable SD card and play around with nmtui a bit to see how that works out.
RE: No internet access through Pinephone hot spot - by Zebulon Walton - 12-23-2020, 04:20 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,965 03-25-2024, 09:07 AM
Last Post: anonymous
  Mobile internet via cellular network mostly not working Anna 18 10,217 01-19-2024, 02:59 AM
  unofficial kali linux for pinephone help needed pinesmell 5 3,614 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Axolotl on PinePhone / Mobian arno_nuehm 219 164,983 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,319 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,164 03-01-2023, 04:45 PM
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,189 12-22-2022, 07:10 PM
Last Post: acid andy
  Sending Pinephone SMS from Desktop biketool 5 2,900 09-13-2022, 01:46 PM
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,851 09-11-2022, 09:24 PM
Last Post: Katsujinken
  How to get Pinetime working with Pinephone arkadione 12 7,280 08-28-2022, 12:30 PM
Last Post: Fish
