No internet access through Pinephone hot spot
(12-23-2020, 08:48 AM)Zebulon Walton Wrote: I decided to try out the wifi hot spot feature since that looks like something that could be useful. Out of the box, the "Turn on Wi-Fi Hotspot" 3 dots menu item in Settings/Wi-Fi is greyed out. So I set it up via command line per the Mobian wiki :
If you start with a fresh Mobian install then I suspect it should work out of the box. You have to enable WiFi first, then the "Turn on WiFi Hotspot" option will be available in the hamburger menu.
The reason I say "suspect/should" is I use USB or ethernet tethering. For sure USB tethering does indeed work out of the box on Mobian, ethernet tethering needs a tweak that can be done via the nmtui user interface. I have a multi-port USB-C dongle that includes an RJ45 socket: plug it all in then go into nmtui, edit the wired connection and change the IPv4 configuration to "Shared" (from Automatic). (In the early days this sharing was also required for USB; in fact I suspect it may be what is missing from your connection and a quick nmtui may fix things?)
  • ROCKPro64 v2.1 2GB, 16Gb eMMC for rootfs, SX8200Pro 512GB NVMe for /home, HDMI video & sound, Bluetooth keyboard & mouse. Arch (5.19 kernel, Openbox desktop) for general purpose daily PC.
  • PinePhone Pro Explorer Edition daily driver, Tow-boot on SPI, Arch/phosh on eMMC
  • PinePhone BraveHeart now v1.2b 3/32Gb, Tow-boot with Arch/Phosh on eMMC
RE: No internet access through Pinephone hot spot - by dukla2000 - 12-23-2020, 03:40 PM
  Sending Pinephone SMS from Desktop biketool 5 272 09-13-2022, 01:46 PM
Last Post: anonymous
  Axolotl on PinePhone / Mobian arno_nuehm 188 83,235 09-12-2022, 02:55 AM
Last Post: Eugo
  [SOLVED] Lost Internet connectivity after recent update drh 3 340 09-11-2022, 09:24 PM
Last Post: Katsujinken
  How to get Pinetime working with Pinephone arkadione 12 1,741 08-28-2022, 12:30 PM
Last Post: Fish
  unofficial kali linux for pinephone help needed pinesmell 3 1,029 08-23-2022, 01:45 AM
Last Post: Shubhamvis98
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 216 08-06-2022, 01:10 AM
Last Post: elode
  Battery problem with a Pinephone keyboard and Mobian elode 0 243 07-26-2022, 06:25 AM
Last Post: elode
  cryptocurrency on mobian/pinephone biketool 31 9,311 06-15-2022, 03:14 PM
Last Post: Hobbes42
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 1,159 06-02-2022, 07:16 AM
Last Post: arkadione
  Blueman GUI Bluetooth Network Access Point - fixing Bridging biketool 12 2,229 05-26-2022, 05:56 AM
