Power switch circuit
(01-29-2016, 02:02 AM)Gearsoul Wrote:
(01-28-2016, 10:21 AM)pine.tree Wrote:
(01-28-2016, 09:59 AM)patrickhwood Wrote: I believe the switch that's on the board is actually a momentary contact that's connected to the PMIC.  A short press of the switch when the system is running generates an interrupt to the SoC from the PMIC, causing a soft power off with a graceful system shutdown.  A long hold (16 secs according to the AXP803 PMIC datasheet) forces the PMIC into a powered-off state, where it just shuts off the power to everything.
Pressing the power button when the board is off powers on the PMIC, which powers up all the devices on the board.
Ah, that would be great. I forgot about the ability to either force shutdown or "gracefully" shutdown the device. I certainly wouldn't want to abruptly cut power, shutting down properly is good. If they do the momentary contact switch, 10/10.
... :/c Huh, so... if I use the Gameboy power switch, I'll actually be forcing a hard shutdown instead of the 'graceful' soft shutdown? That sounds like it would be bad? Maybe... if I only turn it off after closing everything it would be okay..?
Hardware maybe this pine64 have not shutdown ,
but software android have .
https://play.google.com/store/search?q=shutdown&c=apps
For Linux , have command set time to shutdown your pine64 and mouse can shutdown your pine64 , this is not problem
Power switch circuit - by drewh - 01-15-2016, 01:28 PM
RE: Power switch circuit - by tllim - 01-15-2016, 02:16 PM
RE: Power switch circuit - by SkimMilk - 01-23-2016, 11:05 AM
RE: Power switch circuit - by tllim - 01-23-2016, 11:55 AM
RE: Power switch circuit - by By-Jokese - 01-24-2016, 05:26 AM
RE: Power switch circuit - by Ghost - 01-24-2016, 06:04 AM
RE: Power switch circuit - by Gearsoul - 01-28-2016, 08:59 AM
RE: Power switch circuit - by SkimMilk - 01-28-2016, 09:15 AM
RE: Power switch circuit - by pine.tree - 01-28-2016, 09:31 AM
RE: Power switch circuit - by patrickhwood - 01-28-2016, 09:59 AM
RE: Power switch circuit - by pine.tree - 01-28-2016, 10:21 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 02:02 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 05:53 AM
RE: Power switch circuit - by joe - 01-29-2016, 06:00 AM
RE: Power switch circuit - by mFinnholm - 05-25-2016, 04:49 AM
RE: Power switch circuit - by MokaMx_GDL_DE - 07-05-2016, 07:00 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 06:03 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 06:36 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 06:38 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 07:03 AM
RE: Power switch circuit - by janjwerner - 03-06-2016, 09:36 AM
RE: Power switch circuit - by 1q84 - 03-11-2016, 02:28 AM
RE: Power switch circuit - by tllim - 03-11-2016, 03:04 AM
RE: Power switch circuit - by MichaelMeissner - 03-06-2016, 11:12 AM
RE: Power switch circuit - by tllim - 03-06-2016, 11:24 AM
RE: Power switch circuit - by mribunal - 03-09-2016, 05:13 PM
RE: Power switch circuit - by janjwerner - 03-06-2016, 11:20 AM
Power switch circuit - by SkimMilk - 03-09-2016, 05:34 PM
RE: Power switch circuit - by norm24 - 03-11-2016, 03:28 AM
RE: Power switch circuit - by tllim - 03-11-2016, 09:29 AM
RE: Power switch circuit - by stevejobs - 04-16-2016, 09:10 AM
Power switch circuit - by SkimMilk - 04-16-2016, 09:22 AM
RE: Power switch circuit - by By-Jokese - 04-18-2016, 12:15 PM
RE: Power switch circuit - by mribunal - 04-19-2016, 03:26 PM
RE: Power switch circuit - by Kiwiboyus - 05-26-2016, 01:46 PM
RE: Power switch circuit - by mFinnholm - 05-27-2016, 12:45 AM
RE: Power switch circuit - by Kiwiboyus - 05-27-2016, 10:29 AM
RE: Power switch circuit - by Kiwiboyus - 05-27-2016, 06:00 PM
RE: Power switch circuit - by g_t_j - 06-02-2016, 03:26 PM
RE: Power switch circuit - by janjwerner - 06-02-2016, 08:05 PM
RE: Power switch circuit - by tllim - 06-03-2016, 11:13 AM
RE: Power switch circuit - by pfeerick - 06-03-2016, 06:21 PM
RE: Power switch circuit - by tampadave - 09-19-2016, 09:17 AM
Power switch circuit - by bonterra - 07-05-2016, 07:16 AM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 5,958 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 6,206 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 20,645 01-05-2017, 12:37 AM
Last Post: swinging
  Power Off / Reset Buttons - DietPi casmiguefl 4 11,433 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 56,433 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 7,396 02-10-2016, 07:14 PM
  USB HDD Power eender 5 12,569 02-06-2016, 09:30 PM
Last Post: blktiger
