Power switch circuit
#43
(07-05-2016, 07:00 AM)MokaMx_GDL_DE Wrote: I found this quiet tricky.. the switch is actually to turn on more like a reset. if you are running on the system with an OS then you do not want to have a off switch that corrupt the OS. when connect the power the board automatically turn on. but if you shout down the system from the OS. you do not need an off switch. you only need the button to turn on the system after you shutdown from the OS.!!! this is working. beside this would be more secure to switch the power supply off to avoid any power during attaching or handling the board an connections.
Why not have the button send a shutdown signal to the OS, like any other modern OS?
Just about every computer will send a soft shutdown signal (to the OS) on a short press and a hard shutdown signal on a long press.
Backer #16374 - KS funded January 23rd 2016 - Backerkit funded on March 10th 2016 - BOARD RECEIVED ON JUNE 29th - BACKERKIT ORDER FULFILLED ON SEPT 8th
Power switch circuit - by drewh - 01-15-2016, 01:28 PM
RE: Power switch circuit - by tllim - 01-15-2016, 02:16 PM
RE: Power switch circuit - by SkimMilk - 01-23-2016, 11:05 AM
RE: Power switch circuit - by tllim - 01-23-2016, 11:55 AM
RE: Power switch circuit - by By-Jokese - 01-24-2016, 05:26 AM
RE: Power switch circuit - by Ghost - 01-24-2016, 06:04 AM
RE: Power switch circuit - by Gearsoul - 01-28-2016, 08:59 AM
RE: Power switch circuit - by SkimMilk - 01-28-2016, 09:15 AM
RE: Power switch circuit - by pine.tree - 01-28-2016, 09:31 AM
RE: Power switch circuit - by patrickhwood - 01-28-2016, 09:59 AM
RE: Power switch circuit - by pine.tree - 01-28-2016, 10:21 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 02:02 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 05:53 AM
RE: Power switch circuit - by joe - 01-29-2016, 06:00 AM
RE: Power switch circuit - by mFinnholm - 05-25-2016, 04:49 AM
RE: Power switch circuit - by MokaMx_GDL_DE - 07-05-2016, 07:00 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 06:03 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 06:36 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 06:38 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 07:03 AM
RE: Power switch circuit - by janjwerner - 03-06-2016, 09:36 AM
RE: Power switch circuit - by 1q84 - 03-11-2016, 02:28 AM
RE: Power switch circuit - by tllim - 03-11-2016, 03:04 AM
RE: Power switch circuit - by MichaelMeissner - 03-06-2016, 11:12 AM
RE: Power switch circuit - by tllim - 03-06-2016, 11:24 AM
RE: Power switch circuit - by mribunal - 03-09-2016, 05:13 PM
RE: Power switch circuit - by janjwerner - 03-06-2016, 11:20 AM
Power switch circuit - by SkimMilk - 03-09-2016, 05:34 PM
RE: Power switch circuit - by norm24 - 03-11-2016, 03:28 AM
RE: Power switch circuit - by tllim - 03-11-2016, 09:29 AM
RE: Power switch circuit - by stevejobs - 04-16-2016, 09:10 AM
Power switch circuit - by SkimMilk - 04-16-2016, 09:22 AM
RE: Power switch circuit - by By-Jokese - 04-18-2016, 12:15 PM
RE: Power switch circuit - by mribunal - 04-19-2016, 03:26 PM
RE: Power switch circuit - by Kiwiboyus - 05-26-2016, 01:46 PM
RE: Power switch circuit - by mFinnholm - 05-27-2016, 12:45 AM
RE: Power switch circuit - by Kiwiboyus - 05-27-2016, 10:29 AM
RE: Power switch circuit - by Kiwiboyus - 05-27-2016, 06:00 PM
RE: Power switch circuit - by g_t_j - 06-02-2016, 03:26 PM
RE: Power switch circuit - by janjwerner - 06-02-2016, 08:05 PM
RE: Power switch circuit - by tllim - 06-03-2016, 11:13 AM
RE: Power switch circuit - by pfeerick - 06-03-2016, 06:21 PM
RE: Power switch circuit - by tampadave - 09-19-2016, 09:17 AM
Power switch circuit - by bonterra - 07-05-2016, 07:16 AM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 5,958 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 6,206 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 20,645 01-05-2017, 12:37 AM
Last Post: swinging
  Power Off / Reset Buttons - DietPi casmiguefl 4 11,433 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 56,356 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 7,396 02-10-2016, 07:14 PM
  USB HDD Power eender 5 12,569 02-06-2016, 09:30 PM
Last Post: blktiger
