Power switch circuit
#42
(01-28-2016, 09:59 AM)patrickhwood Wrote:
(01-28-2016, 09:31 AM)pine.tree Wrote:
(01-28-2016, 09:15 AM)SkimMilk Wrote:
(01-28-2016, 08:59 AM)Gearsoul Wrote: When you guys say 'switch' ... do you mean the physical component that toggles?
So... the on/off switch of the classic Gameboy serves this purpose, and no additional component is needed to make use of on/off functionality?
Yes, the physical switch where you can turn on / off the Pine.
Currently on the board, there are connections for it, but no physical switch soldered on.
It was supposed to come as a stretch goal reward but there were some people who were negative about having the switch, thus it is now dangling in the air.
I don't see why they cannot have the switch there, and just leave it in the 'on' position if they do not want to use it?
I would love to see the switch there, so that I can turn on/off the Pine as and when I want, rather than pulling the power cable off...  Big Grin
I definitely agree. A switch would be great, i would love not to have to pull out cords or something, just a little flick of a switch is what i would prefer. If Pine decides not to include a power switch, you can always take a broken flashlight apart and use the click switch Tongue
I believe the switch that's on the board is actually a momentary contact that's connected to the PMIC.  A short press of the switch when the system is running generates an interrupt to the SoC from the PMIC, causing a soft power off with a graceful system shutdown.  A long hold (16 secs according to the AXP803 PMIC datasheet) forces the PMIC into a powered-off state, where it just shuts off the power to everything.
Pressing the power button when the board is off powers on the PMIC, which powers up all the devices on the board.
I found this quiet tricky.. the switch is actually to turn on more like a reset. if you are running on the system with an OS then you do not want to have a off switch that corrupt the OS. when connect the power the board automatically turn on. but if you shout down the system from the OS. you do not need an off switch. you only need the button to turn on the system after you shutdown from the OS.!!! this is working. beside this would be more secure to switch the power supply off to avoid any power during attaching or handling the board an connections.
Power switch circuit - by drewh - 01-15-2016, 01:28 PM
RE: Power switch circuit - by tllim - 01-15-2016, 02:16 PM
RE: Power switch circuit - by SkimMilk - 01-23-2016, 11:05 AM
RE: Power switch circuit - by tllim - 01-23-2016, 11:55 AM
RE: Power switch circuit - by By-Jokese - 01-24-2016, 05:26 AM
RE: Power switch circuit - by Ghost - 01-24-2016, 06:04 AM
RE: Power switch circuit - by Gearsoul - 01-28-2016, 08:59 AM
RE: Power switch circuit - by SkimMilk - 01-28-2016, 09:15 AM
RE: Power switch circuit - by pine.tree - 01-28-2016, 09:31 AM
RE: Power switch circuit - by patrickhwood - 01-28-2016, 09:59 AM
RE: Power switch circuit - by pine.tree - 01-28-2016, 10:21 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 02:02 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 05:53 AM
RE: Power switch circuit - by joe - 01-29-2016, 06:00 AM
RE: Power switch circuit - by mFinnholm - 05-25-2016, 04:49 AM
RE: Power switch circuit - by MokaMx_GDL_DE - 07-05-2016, 07:00 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 06:03 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 06:36 AM
RE: Power switch circuit - by Gearsoul - 01-29-2016, 06:38 AM
RE: Power switch circuit - by Ghost - 01-29-2016, 07:03 AM
RE: Power switch circuit - by janjwerner - 03-06-2016, 09:36 AM
RE: Power switch circuit - by 1q84 - 03-11-2016, 02:28 AM
RE: Power switch circuit - by tllim - 03-11-2016, 03:04 AM
RE: Power switch circuit - by MichaelMeissner - 03-06-2016, 11:12 AM
RE: Power switch circuit - by tllim - 03-06-2016, 11:24 AM
RE: Power switch circuit - by mribunal - 03-09-2016, 05:13 PM
RE: Power switch circuit - by janjwerner - 03-06-2016, 11:20 AM
Power switch circuit - by SkimMilk - 03-09-2016, 05:34 PM
RE: Power switch circuit - by norm24 - 03-11-2016, 03:28 AM
RE: Power switch circuit - by tllim - 03-11-2016, 09:29 AM
RE: Power switch circuit - by stevejobs - 04-16-2016, 09:10 AM
Power switch circuit - by SkimMilk - 04-16-2016, 09:22 AM
RE: Power switch circuit - by By-Jokese - 04-18-2016, 12:15 PM
RE: Power switch circuit - by mribunal - 04-19-2016, 03:26 PM
RE: Power switch circuit - by Kiwiboyus - 05-26-2016, 01:46 PM
RE: Power switch circuit - by mFinnholm - 05-27-2016, 12:45 AM
RE: Power switch circuit - by Kiwiboyus - 05-27-2016, 10:29 AM
RE: Power switch circuit - by Kiwiboyus - 05-27-2016, 06:00 PM
RE: Power switch circuit - by g_t_j - 06-02-2016, 03:26 PM
RE: Power switch circuit - by janjwerner - 06-02-2016, 08:05 PM
RE: Power switch circuit - by tllim - 06-03-2016, 11:13 AM
RE: Power switch circuit - by pfeerick - 06-03-2016, 06:21 PM
RE: Power switch circuit - by tampadave - 09-19-2016, 09:17 AM
Power switch circuit - by bonterra - 07-05-2016, 07:16 AM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 5,958 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 6,206 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 20,645 01-05-2017, 12:37 AM
Last Post: swinging
  Power Off / Reset Buttons - DietPi casmiguefl 4 11,433 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 56,356 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 7,396 02-10-2016, 07:14 PM
  USB HDD Power eender 5 12,569 02-06-2016, 09:30 PM
Last Post: blktiger
