Making nextcloud sync work on the phone
I was able to get Nextcloud working by manually editing the config file. The only apparent problem with Nextcloud is that I can't scale it to fit the screen. Usually, I can switch the orientation and see just enough of the GUI do to what I need to do, but I would rather figure out a way to force it to scale.
Generally, there's a problem with Mobian where you'll force an app to scale, and then any new window or dialog that app pops up will not be forced to scale. I suppose that's a separate issue, though.
RE: Making nextcloud sync work on the phone - by 3x5co - 01-02-2021, 07:58 PM
  Alarm clock doesn’t work Captain1ndustry 13 23,819 12-15-2024, 07:07 PM
Last Post: baptx
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 7,547 08-05-2024, 06:12 AM
Last Post: baptx
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 5,538 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 5,029 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 11,982 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  Nextcloud Calendar and Contacts mark1250 3 3,412 12-29-2022, 07:27 PM
Last Post: mark1250
Exclamation The webcam doesn't work in Firefox anonymous 0 1,688 11-06-2022, 01:45 PM
Last Post: anonymous
  phone does not ring (when sleeping) jsch 2 3,546 10-07-2022, 08:08 AM
  Megapixels doesn't work Glenn 4 5,964 08-28-2022, 03:19 PM
Last Post: vortex
