Screen flicker with USB-C charging
Just to confirm that after a recent kernel upgrade (I lost track when but it might be related to when the DP patch was introduced ?) I now have the exact same problem, including to the current kernel 5.10.2 :
When computer turned off:
USB-C PD charger works.
When computer turned on:
USB-C PD charger and cable: After a few seconds, the "charge icon" starts to blink (i.e.: laptop battery charger sees the cable constantly plugged in and out in quick successions) and the screen starts to blink (i.e.: power manager constantly switches brightness between "on battery" and "on charger" level).
USB-C to USB-A cable and plain USB-A "Smart Charge" port on the same charger: works normally
Barrel to USB-A cable : works normally too.
RE: Screen flicker with USB-C charging - by DrYak - 01-03-2021, 05:08 PM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 296 02-23-2024, 04:22 PM
Last Post: tuxxpine
Photo P{inebook Pro not charging Ome Ko 6 1,999 11-09-2023, 03:29 PM
Last Post: tomekdev
  Black screen by start up bluedemon382 10 2,949 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,009 04-01-2023, 07:55 AM
Last Post: hacknix
  Pine Book Pro Charging Problems balin 7 6,907 12-15-2022, 02:15 PM
Last Post: tomasgreenro
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 1,986 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,086 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,743 05-09-2022, 05:53 AM
Last Post: gerstavros
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,519 02-22-2022, 11:20 AM
  Putting my screen on TV S265 6 4,740 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
