Proximity sensor rubber pad gasket replacement
My braveheart pinephone never had the small gasket that covers the proximity sensor. This causes the proximity sensor to provide bad readings to phosh and blanks the screen. Now after making a phosh based image I edit the udev rules to disable the proximity sensor. I was hoping the replacement mainboard would include the proximity sensor cover, but it did not. Though an uncommon problem I'm not the only one to have this issue based on the various messages on the forum.
I tried the fix shown by RWXYZ, but I'm having trouble getting the tiny pieces aligned correctly. See https://forum.pine64.org/showthread.php?...=proximity
Does anyone have a 3D printable fix for the proximity and light sensor gasket? I might be able to get a friend to print it some versions.
Any other thoughts on potential fixes? I'm missing the part so don't know exactly what is needed.
Proximity sensor rubber pad gasket replacement - by puffchumpy - 12-12-2020, 08:50 AM
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,277 10-12-2023, 01:03 PM
Last Post: robthebold
  Screen Replacement Instructions erikkugel 4 3,089 09-07-2022, 11:04 PM
Last Post: RTP
  Microphone replacement SocialNetworkingWasAMistake 1 1,517 08-05-2022, 03:16 PM
Last Post: calinb
  Screen replacement Csanderson0313 4 3,193 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Replacement Loud Speaker kmsgli 18 14,349 11-01-2021, 12:25 PM
Last Post: mickclark430
  LCD panel replacement instructions mob 2 2,218 09-13-2021, 05:11 PM
Last Post: mob
  Battery replacement alternative sax1960 7 6,243 08-29-2021, 07:03 AM
Last Post: bcnaz
  inner earpiece speaker replacement dcinoz 4 4,374 07-24-2021, 04:37 AM
Last Post: dcinoz
  Screen or motherboard replacement? Static Face 2 2,923 06-08-2021, 12:57 AM
Last Post: Static Face
  Mainboard replacement does not boot/charge boarf 2 2,750 05-02-2021, 10:47 AM
Last Post: boarf
