SD card / Sim slot dilemma
(12-11-2020, 04:09 AM)zez Wrote: Hi everybody.
I have a problem with my pinephone manjaro ce. Recently I decided to flash the internal emmc through the sd card (jumpstart option).
I was surprised to find out that the phone doesn't recognize the sd card (checked via lsblk command), but a phone sim is detected correctly.
Has my phone a hardware fault ? Do I have to config some software option alternatively ? I'm stuck....
Thank you in advance
P.S.
Sorry for my awful english
Hi there - it is unlikely you have a hardware fault but anything is possible. It is not clear from your report how you are detecting things that work:
 - what is the phone configuration when you run lsblk - where do you run lsblk from? Try sudo blkid as well.
 - you say the sim is detected - again what is the phone config when this happens?
Most likely you just need JumpDrive version 0.6?
SD card / Sim slot dilemma - by zez - 12-11-2020, 04:09 AM
RE: SD card / Sim slot dilemma - by ryo - 12-11-2020, 07:35 AM
RE: SD card / Sim slot dilemma - by dukla2000 - 12-11-2020, 10:32 AM
RE: SD card / Sim slot dilemma - by zez - 12-14-2020, 10:08 AM
  Cannot pay with credit card: VISA: "card was declined." hannaconner 0 1,623 07-15-2025, 10:56 PM
Last Post: hannaconner
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 2,602 04-11-2024, 03:10 PM
  Cannot pay with credit card: VISA: "card was declined.". MasterCard: "Bad Gateway". dreieck 4 6,803 04-15-2023, 04:21 PM
Last Post: pinkkat
  Credit card rejected by the bank farleymartinez 4 5,351 12-14-2022, 12:03 PM
Last Post: fxc
  sd card wear vs partition size guenther 2 3,394 11-07-2021, 11:11 AM
Last Post: guenther
  sd card limits cmcanulty 2 5,336 06-19-2019, 05:43 AM
Last Post: cmcanulty
Question Does the Rock64 single board computer (1, 2 or 4 GB ram) have a PCie slot? IP_Proxy 5 9,358 04-29-2019, 08:19 PM
  Purchasing with credit card blindson76 0 3,443 06-08-2018, 12:25 PM
Last Post: blindson76
