(02-16-2021, 05:14 AM)mw4jet Wrote:(12-10-2020, 04:53 PM)RTP Wrote: From time to time my previously well paired bluetooth headphones refuse to keep a connection to my Pinephone.Thank you for this, I have been using VLC for podcasts and I get the random bluetooth disconnect. It is with the screen off and is anywhere from 5 to 7 minutes. When I turn the screen back on the sound emits from the speakers but plays, stops, plays, stops, etc. I will try Lolypop, do you also use gPodder?
No matter how many times I rebooted/upgrade, systemctl restart bluetooth, off/on bluetooth back and forth connect attempts repeatedly w/intermittently stopping of bluetooth on the phone. Still, no bluetooth connection sticking (with previously setup and working well bluetooth headphones).
When I viewed systemctl status bluetooth in terminal, I found this (MAC OUI left as is):
Code:Dec 10 17:03:03 mobian bluetoothd[485]: sap-server: Operation not permitted (1)
Dec 10 17:03:07 mobian bluetoothd[485]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/sbc
Dec 10 17:03:07 mobian bluetoothd[485]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/sbc
Dec 10 17:22:52 mobian bluetoothd[485]: src/profile.c:ext_connect() Headset Voice gateway failed connect to FC:58:FA:X:X:X: Connection refused (111)
Dec 10 17:22:52 mobian bluetoothd[485]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to FC:58:FA:X:X:X: Permission denied (13)
Dec 10 17:22:56 mobian bluetoothd[485]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to FC:58:FA:X:X:X: Software caused connection abort (103)
Dec 10 17:23:06 mobian bluetoothd[485]: src/profile.c:ext_connect() Headset Voice gateway failed connect to FC:58:FA:X:X:X: Connection refused (111)
Dec 10 17:23:06 mobian bluetoothd[485]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to FC:58:FA:X:X:X: Permission denied (13)
Since this has happened to me numerous times (seemingly completely random), a simple fix is to completely remove the previously setup bluetooth device on the Pinephone, and then readd it from scratch:
Code:bluetoothctl
In bluetoothctl I entered:
Code:remove FC:58:FA:X:X:X
After removing the device completely, I was able to reconnect by starting the pair over again from scratch.
I used bluetoothctl (there is also a "Remove Device" under Bluetooth settings in Mobian).
I don't know if this helps anyone or not, but I am sharing in case it helps someone shares the same frustrating problem. Outside this Bluetooth has really improved in functionality (besides the weak connection mentioned in another thread).
To add: I am really happy with the noticeable progress (to think, just a few months ago, no bluetooth headphones were usable, now I rarely experience problems).
Great progress. Now I can listen to Podcasts without a problem (tip: set podcasts to use Lolipop to prevent sound cutouts on 'blankscreen').
Thank you to all contributors!
Yes, Gpodder for managing my Podcasts and Lolipop is really nice for playing them. It has a great interface. You can see me using Gpodder and Lolipop starting at 1:47 of this video: https://youtu.be/Z_Cuhuu2xwI
On default app, not only does sound cut on blank screen, another thing I noticed (in the default player on most Phosh) is it doesn't even have a visual representation of the pause/play buttons. So the default player I would have to poke around with my finger until it found the pause button.
Definitely give Lolipop a look.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
