i2c-bus kernel modules
I don't have much clues since the bus are showing but empty.
On my Pine64, I have it running fine with an MCP23017 GPIO expander.
I don't have any kernel module to load since I've compiled my own kernel from longsleep repo with the CONFIG_I2C_CHARDEV=y, so built-in in the kernel.
Are you using pin 3 and 5 on Pi header ? Are you sure you didn't invert them ?
You can also check if DTS is properly set by doing "hd /proc/device-tree/soc\@01c00000/pinctrl\@01c20800/twi1\@0/allwinner\,pins", it should display "PH2.PH3".
i2c-bus kernel modules - by robertvaldimarsson - 06-02-2016, 02:42 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 07:47 AM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 09:16 AM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 01:49 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 03:06 PM
RE: i2c-bus kernel modules - by dkryder - 06-03-2016, 05:32 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 03:48 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 06:04 PM
RE: i2c-bus kernel modules - by martinayotte - 06-03-2016, 08:13 PM
RE: i2c-bus kernel modules - by peterz - 06-07-2016, 01:01 PM
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 556,287 05-21-2018, 06:30 AM
Last Post: Luke
  how to set kernel parameter 'fsck.mode=force' marcelser 6 14,988 05-09-2018, 09:07 PM
Last Post: pfeerick
Question Debian Jessie with 4.x.y kernel and complete hardware support? Spark 2 7,094 04-24-2017, 09:56 PM
Last Post: Spark
  Adding a missing kernel module spz2k 8 14,874 01-10-2017, 06:22 AM
Last Post: xalius
  NIC not visible after kernel update xleon 1 4,037 11-15-2016, 05:23 PM
Last Post: xleon
  [OUTDATED] Debian Jessie (4.7.0-rc1 Kernel) Images fire219 4 19,230 07-20-2016, 02:36 PM
Last Post: umiddelb
  How to install modules into system? MicroDiery 6 10,117 05-27-2016, 06:44 PM
Last Post: JamesHarris
  Debian kernel upgrade question jl_678 2 5,833 04-18-2016, 05:54 PM
Last Post: jl_678
