Pinebook Pro Dock Power Requirements
(12-06-2020, 04:54 PM)KC9UDX Wrote: The PBP currently (pun?) only draws about 2.5A from the USB-C connector in any case.  Except for future modifications, more than 15W won't do any good.  Reports are that it draws closer to 3A from the barrel jack; and the power circuitry would need a major redesign to accept more than that.
I don't think it would be a major redesign.  The main power supply, a BQ24171, is rated to 17V.  It should be possible to get 45W with 15V-3A over USB-C with only minor changes to a few components.
(12-07-2020, 09:58 PM)calinb Wrote: I still don't know what PD modes the dock will request. This power supply supports more modes than most. I wonder if it would work. The power supplies I've seen all peak at 3 or 3.25A so 20 V would be required to make it to the 60W dock spec.
Input: 100~240V / 50~60Hz; Output: 65W, 5V-3A, 9V-3A, 12V-3A, 15V-3A, 18V-3A, 20V-3.25A
The USB PD spec allows up to 3A without a fancier cable that has a chip in it.  So usually a power supply with top out at 3A.  Only for >60W will >3A be used, since the max voltage is 20V and it's required.
The spec only requires voltages of 5V, 9V, 15V, and 20V, and only if the adapter is powerful enough to reach 3A at the previous voltage.  So the 12V and 18V are optional voltages that adapter has that will be less common.
I wonder if the schematic for the dock will be available.  I've never worked on hardware with an externally powered USB hub and don't know what's done.  Does it have a buck-boost supply to allow any combination of input and output voltage?  Or does it just have a buck converter to 5V, so you can get either 5V or the input voltage?  Do they do dynamic power management as new USB-PD devices are attached?
Pinebook Pro Dock Power Requirements - by calinb - 12-06-2020, 11:34 AM
RE: Pinebook Pro Dock Power Requirements - by xyzzy - 12-11-2020, 03:30 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 233 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 180 02-17-2024, 07:06 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 0 152 02-13-2024, 10:43 PM
Last Post: segaloco
  Pine Dock Networking Issue trillobite 1 182 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 526 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 956 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 127,109 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 5,713 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,142 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 131,787 11-30-2022, 04:28 PM
