Pinebook pro no longer boots
You need to unscrew the backplate and disable EMMC. Then reboot from sd card while switching the EMMC on after a couple of seconds.
I usually do this on a side of a table so I can keep the display part open, avoiding possible damages to the hinge that may occur opening the display.
Refer to the pinebook wiki to find the EMMC toggle
If the eMMC module is enabled after boot from an SD card (i.e you are too slow switching the emmc toggle), you can enable the EMMC with the following commands as user "root";
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
Pinebook pro no longer boots - by xsquared93 - 12-06-2020, 10:02 AM
RE: Pinebook pro no longer boots - by FeMike - 12-08-2020, 03:21 PM
RE: Pinebook pro no longer boots - by xsquared93 - 12-10-2020, 12:09 PM
RE: Pinebook pro no longer boots - by nightranger73 - 12-10-2020, 01:33 PM
RE: Pinebook pro no longer boots - by TheLastDon - 01-02-2021, 03:33 AM
RE: Pinebook pro no longer boots - by wdt - 02-13-2021, 09:39 AM
  Pinebook Pro Initial Impressions kunger 442 583,386 1 hour ago
Last Post: dachalife
  looking to buy one pinebook pro (mainland China) duanduan 3 2,229 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 372 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 275 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 268 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 203 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 629 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 695 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,446 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,156 12-15-2023, 02:11 PM
