Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
#51
(05-09-2021, 10:59 AM)8bit Wrote: Could be a ground loop.
Could you, please, explain a bit how could it be a ground loop?  Yes, there was an UTP (i.e. not shielded) Ethernet cable connected to the Gigabit Ethernet dongle, but the network switch on the other end probably has isolation transformers on its ports; I haven't opened it so I don't know for sure.  Thus, there should be no conductive path between the two grounds, one in the PineBook Pro and the other one in the network switch.
RE: PineBook Pro revision 2.2: Wishlist for the hardware issue fixes - by dsimic - 05-09-2021, 11:07 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 380 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 303 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 243 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 234 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 579 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,032 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 128,991 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 2,898 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 5,906 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,300 12-27-2022, 03:31 PM
Last Post: samtux
