Possible reason why MANY applications dont work properly in Manjaro on the PinePhone
(12-04-2020, 08:55 AM)Lousy Fisherman Wrote: This is one of my biggest problems in integrating a Voice Assistant into the phone. I need to talk to various applications, the D-Bus, and sensors. Many times there are different versions of libraries within a distro, and in between distros, different libraries within distros and between distros, on aarch64, which limits choice Tongue. Mobian is both the easiest and the hardest to get everything running. Easiest, because it has more libraries than any other distro, and harder, because the libraries tend to be older and more stable so missing functionality that I need.
I wrap, hack, and patch a lot of stuff Tongue
YMMV
LF
Sounds like fun, and a lot of time invested in that fun Smile are you developing something right now?
RE: Possible reason why MANY applications dont work properly in Manjaro on the PinePhone - by kern707 - 12-04-2020, 09:46 AM
  systemic issue pinephone penguins_rule 3 411 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 231 03-19-2024, 10:36 AM
Last Post: penguins_rule
  Manjaro: Settings doesnt open nbh 0 590 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,491 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,602 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 1,806 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 807 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,751 03-02-2023, 07:25 PM
  Can't add micro SD card to Pinephone thorensjubilee 7 2,523 02-27-2023, 10:21 AM
Last Post: mikehenson
  Can't install Manjaro thorensjubilee 1 1,023 02-09-2023, 08:17 AM
