Thermal imaging solution board for the PinePhone board
(12-04-2020, 03:36 PM)wibble Wrote: Presumably it would work with libraries like the adafruit python one:
https://cdn-learn.adafruit.com/downloads...sensor.pdf
If it's aimed at the pinephone rather than more generic usage it should probably have the option to connect direct to the pogo pins similar to the way the breakout cable does. I'd be careful of proximity to the antenna.
I guess you've already seen Martijn Braam's post about the MLX90640:
https://blog.brixit.nl/making-a-backcove...pinephone/
I tried the Adafruit one without success as of today. (Now reading Martjin´s post, as the work is aimed for the Raspberry Pi this might be why).
The direct connection could be for a later stage, the current system is aimed for prototyping.
Thanks a lot for the link, I have not seen it before.  I will for sure take a closer look at Martjin´s work!.
RE: Thermal imaging solution board for the PinePhone board - by jnpine - 12-04-2020, 04:27 PM
  Pinephone (Pro) Keyboard Case for sale manubert 3 13,073 08-26-2025, 06:06 AM
Last Post: zetabeta
  Replacement battery for PinePhone? j_s 9 4,654 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 3,514 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 14,099 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 3,140 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 3,402 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 1,863 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 3,065 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 9,435 06-26-2024, 07:11 AM
Last Post: dachalife
  Case for Pinephone totilele 13 16,276 04-11-2024, 11:48 AM
Last Post: gramonyl
