Cluster / Render Farm
Just found this thread! I've been testing my pine in setting up a hadoop server so haven't spent much time on the forums. I also am a part time animator/producer (Wanderers Wood) and use the CGA software Animation Master. A:M has the ability to render frames to a farm (they use their own app called Netrender). The hitch there is that it is either windows or apple. It would be interesting to see if the pine could be extended to perform as a render farm for A:M.
I'm willing to do the leg work of doing a proof in concept between A:M and pine, IF there is an interest from the pine folks. Since i am a full time integration developer, my animation work usually is done in the off hours, so time is limited. But since I need a render farm, and the whole idea of a bank of pines that can be solar powered is truly exceptional, I'm willing to work towards that end.
Also, if a moderator is still needed, I'd be willing to take that on if need be.
Cluster / Render Farm - by Ron Piggott - 01-15-2016, 05:20 AM
RE: Cluster / Render Farm - by drag00n - 01-15-2016, 09:23 AM
RE: Cluster / Render Farm - by tllim - 01-15-2016, 10:59 AM
RE: Cluster / Render Farm - by Ron Piggott - 01-16-2016, 08:35 AM
RE: Cluster / Render Farm - by tllim - 01-16-2016, 10:04 AM
RE: Cluster / Render Farm - by Epsilon - 03-23-2016, 01:26 AM
RE: Cluster / Render Farm - by Sasank - 01-18-2016, 10:10 AM
RE: Cluster / Render Farm - by Madroxprime - 01-28-2016, 06:35 AM
RE: Cluster / Render Farm - by PicoCluster - 02-01-2016, 09:13 PM
RE: Cluster / Render Farm - by Andrew2 - 03-16-2016, 03:33 AM
RE: Cluster / Render Farm - by ataylorm - 02-10-2016, 08:04 AM
RE: Cluster / Render Farm - by tllim - 02-10-2016, 07:01 PM
RE: Cluster / Render Farm - by pharris430 - 09-16-2016, 09:25 AM
RE: Cluster / Render Farm - by pharris430 - 09-19-2016, 11:49 AM
RE: Cluster / Render Farm - by clustercomputing - 09-28-2016, 11:12 PM
RE: Cluster / Render Farm - by tllim - 10-02-2016, 02:55 PM
  I started blogging on Pine64 Cluster salmangano 13 18,302 04-12-2017, 12:44 PM
Last Post: Shad0wSt4R
  Cluster Software Madroxprime 1 5,409 04-03-2017, 06:57 AM
  Bargain 5 Node Cluster of PINE A64+ from Climber.net tllim 8 14,495 10-02-2016, 07:01 AM
Last Post: sheffield_nick
  Pine64 Cluster economy baryluk 5 11,008 06-19-2016, 09:13 AM
Last Post: JasperBrown
  cluster computing jproffer 20 35,911 05-05-2016, 04:13 PM
Last Post: pineresearch
  Cluster capable? W1SPY 7 12,311 02-25-2016, 10:34 PM
Last Post: hrh1818
