pbp no longer boots
If you get boot logo, then the kernel is starting (if it's the bootsplash), or userspace is running if it's the desktop starting screen. So you've gotten significantly farther than u-boot. That really points to a battery problem. Power draw will go up as the GPU is enabled and all the CPU cores run stuff during start up, where you had the crash. One could try measuring battery cell voltage and see if it's dropping too low. There's an alarm signal for SOC and RTT on the battery monitor. Too bad they don't go to a LED.
pbp no longer boots - by tulsums - 12-01-2020, 11:12 AM
RE: pbp no longer boots - by tophneal - 12-01-2020, 01:31 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 03:21 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 06:58 PM
RE: pbp no longer boots - by tophneal - 12-02-2020, 07:59 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 02:07 PM
RE: pbp no longer boots - by KC9UDX - 12-01-2020, 08:56 PM
pbp no longer boots - by tophneal - 12-02-2020, 02:41 PM
RE: pbp no longer boots - by tulsums - 12-02-2020, 03:16 PM
RE: pbp no longer boots - by wdt - 12-02-2020, 06:36 PM
RE: pbp no longer boots - by tulsums - 12-03-2020, 08:16 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 09:53 PM
RE: pbp no longer boots - by wdt - 12-03-2020, 11:29 AM
  Pinebook pro no longer boots xsquared93 7 7,485 02-13-2021, 09:39 AM
Shocked My pbp no longer boots sunjam 2 3,081 12-02-2020, 11:05 PM
Last Post: sunjam
  New Pinebook Pro, only boots 50% of the time micnd90 8 7,806 09-08-2020, 01:25 PM
Exclamation [SOLVED] PBP will no longer power on s3rvant 10 10,228 07-04-2020, 01:57 PM
Last Post: prokofiev
  emmc boots intermittently? haziz 7 7,271 06-08-2020, 07:22 PM
Last Post: mammbo3
