pbp no longer boots
(12-02-2020, 07:59 AM)tophneal Wrote: Have you tried turning off the emmc and booting one of the BSP images from SD, like @KC9UDX  suggested?
If a non-functional bootloader were flashed to the SPI flash, then that would be the 1st choice for the RK3399 to boot from, right? So even with a working SD card and eMMC disabled, it would try to boot from SPI and fail (assuming SPI has a bad bootloader).
If a serial console cable is used, then it should be possible to see if pbp is attempting to boot at all and from what it is booting. Then you narrow down which of the two most likely problems you have, a) bad bootloader, b) bad battery.
pbp no longer boots - by tulsums - 12-01-2020, 11:12 AM
RE: pbp no longer boots - by tophneal - 12-01-2020, 01:31 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 03:21 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 06:58 PM
RE: pbp no longer boots - by tophneal - 12-02-2020, 07:59 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 02:07 PM
RE: pbp no longer boots - by KC9UDX - 12-01-2020, 08:56 PM
pbp no longer boots - by tophneal - 12-02-2020, 02:41 PM
RE: pbp no longer boots - by tulsums - 12-02-2020, 03:16 PM
RE: pbp no longer boots - by wdt - 12-02-2020, 06:36 PM
RE: pbp no longer boots - by tulsums - 12-03-2020, 08:16 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 09:53 PM
RE: pbp no longer boots - by wdt - 12-03-2020, 11:29 AM
  Pinebook pro no longer boots xsquared93 7 7,312 02-13-2021, 09:39 AM
Shocked My pbp no longer boots sunjam 2 3,026 12-02-2020, 11:05 PM
Last Post: sunjam
  New Pinebook Pro, only boots 50% of the time micnd90 8 7,656 09-08-2020, 01:25 PM
Exclamation [SOLVED] PBP will no longer power on s3rvant 10 10,013 07-04-2020, 01:57 PM
Last Post: prokofiev
  emmc boots intermittently? haziz 7 7,093 06-08-2020, 07:22 PM
Last Post: mammbo3
