Installing applicatons via command line
Thanks, just installed linssid via apt and the icon appeared on the Pinephone screen. (Unfortunately it doesn't work. When launched from the command line it says it cannot connect to display :0. Maybe not compatible with Wayland yet.)
Actually it may not be a Wayland issue. The cascade of error messages that come up indicates a possible Qt plugin configuration problem. (Searching online reveals other applications with similar problems.) I was hoping to be able to use the pinephone to do wifi surveys (at least for 2.4GHz). It looks like for now "nmcli d wifi" run from the command line will have to do.
RE: Installing applicatons via command line - by Zebulon Walton - 12-01-2020, 11:24 AM
  Command to test vibration motor? Zebulon Walton 3 4,348 11-12-2023, 08:45 PM
Last Post: zetabeta
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 3,875 01-07-2023, 09:36 AM
Last Post: dcarvil
  ARM Microsoft Teams-problems installing eaglebeckley 15 22,393 01-14-2022, 01:59 AM
Last Post: Tazdevl
  How to Make Mobian Boot to Command Line Ubermunchen 4 6,145 11-02-2021, 08:34 AM
Last Post: ryo
  Installing Mobian --> "Resizing file system" forever Anna 13 19,990 09-09-2021, 04:26 AM
Last Post: spaetz
  Is there a way to do gnome-authenticator via the command line? motox6 0 1,946 05-06-2021, 10:41 PM
Last Post: motox6
  Installing and tweaking Chromium on Mobian and Arch C0ffeeFreak 19 29,296 03-11-2021, 09:24 AM
Last Post: C0ffeeFreak
  "Low Disk Space on Filesystem root" after installing Axolotl and Podcasts Anna 11 14,464 03-05-2021, 02:33 AM
Last Post: Anna
  Installing chromium browser? Zebulon Walton 12 21,063 02-09-2021, 12:33 PM
  installing vpn ergo owl 3 5,674 10-02-2020, 04:22 PM
Last Post: ergo owl
