Cant sign in after update
Make sure you carefully read the terminal screen to check whether there were any errors during update.
In case you didn't reboot yet, you might want to try that first before reflashing.
There is a known bug in Phosh that will redirect you to the login screen right after logging in using the correct pin.
In that case, hold the power button for 20 seconds, and then boot up again.
Cant sign in after update - by Cree - 11-30-2020, 09:24 PM
RE: Cant sign in after update - by ryo - 11-30-2020, 10:32 PM
RE: Cant sign in after update - by MiSimon - 12-01-2020, 02:53 AM
  Using too much juice since last update Eugo 20 3,517 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 1,766 02-13-2024, 01:19 AM
  Latest update Eugo 21 8,190 03-09-2023, 05:27 AM
Last Post: Eugo
  Firefox issue with latest update Barugon 6 2,347 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,171 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to disable automatic update checks bdicewk 4 2,317 06-12-2022, 08:10 AM
Last Post: bdicewk
  Locked out after update bnbcwllc 2 1,582 06-08-2022, 04:46 AM
Last Post: bnbcwllc
  Keyboard case stopped working on pacman update rotwang 5 3,113 05-07-2022, 09:17 PM
Last Post: rotwang
  Pinephone stuck on 'something went wrong' after update gofishus 1 1,573 03-06-2022, 05:48 PM
Last Post: fxc
  Lockup during update, force shut down and try again? tgz 5 5,570 12-22-2021, 03:11 PM
Last Post: tk1107
