eMMC Trouble After Flashing WRONG Image
I booted into a microSD-borne Manjaro on my PinebookPro and used Manjaro's `manjaro-arm-flasher` to permanentize that distribution. In that process, however, I chose the wrong image `rock64` rather than `pbpro` and as a result ended up with a PinebookPro that is not even able to boot from the microSD any longer.
In a first attemtp at remediing this situation I have switched off the eMMC on the main bord - now booting from the microSD is possible. The wiki says the eMMC is hot-pluggable, so I hoped when switching it back on when the system is up and running, I could just reflash it and be fine.
BUT: when toggling the eMMC's hardware switch on the running system, the blockdevice does NOT (re)appear accessible for the `manjaro-arm-flasher` utility.
My next step is trying to have journalctl -f running while toggling the eMMC to have a better feedback of what may be going wrong ...
Can anyone help me out with this situation?
eMMC Trouble After Flashing WRONG Image - by balin - 11-24-2020, 08:14 AM
  What's a good image to use now? [tutorial help as well] frank_philip 40 22,101 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 12,044 03-10-2025, 01:55 PM
  Pinebook Pro upgrading from the factory image yamsoup 12 12,958 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,287 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,748 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 5,427 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 8,319 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 10,937 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 2,550 12-19-2022, 01:01 PM
Last Post: Besouro
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 4,777 10-31-2022, 10:14 AM
