Howto - automatically recover your modem and mobile data after deep sleep
Although I haven't run into the modem problem yet because I haven't used the phone enough for it to be an issue, mguard seems like a good thing so I went ahead and installed it.
I ran "apt-get update && apt-get dist-upgrade" to get all the latest Mobian updates, rebooted, and used the mguard_service_v2.sh file.  A change I made was to put the script into /usr/local/bin instead of /usr/bin, and modify the service file accordingly. Haven't tested it yet aside to see that mguard is running when the phone boots up. A couple of questions...
Is the internet connection name (CON_NAME variable) the same as the APN setting? Also, "ps ax | grep mguard" shows two copies of the script running. Is that the way it is supposed to be working?
RE: Howto - automatically recover your modem and mobile data after deep sleep - by Zebulon Walton - 12-13-2020, 12:52 PM
  Mobile internet via cellular network mostly not working Anna 18 10,631 01-19-2024, 02:59 AM
Last Post: anonymous
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 3,004 06-06-2023, 06:36 AM
Last Post: freelectro
  4G data on default startup / boot dcinoz 1 888 04-29-2023, 11:24 PM
Last Post: dcinoz
  ModemManager debug mode? (Needed to flash modem) calinb 1 1,266 02-27-2023, 04:18 PM
Last Post: calinb
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,651 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,447 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,679 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 17,559 10-29-2022, 09:16 AM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 5,021 09-23-2022, 05:15 AM
  no wakeup from deep-sleep jsch 8 4,251 09-05-2022, 03:03 AM
Last Post: jsch
