Howto - automatically recover your modem and mobile data after deep sleep
(11-24-2020, 08:24 AM)as400 Wrote: Hello @Gribouille,
It's the name you define in Settings --> Mobile --> Access point names.
Usually something like internet.
If you don't trust settings app, try "nmcli" when the modem is connected to mobile data. It will tell you the name of the connection.
I suggest one word name.
Hello @as400,
In France, with Bouygues Telecom the 'Access point names' are detected. The following 'Access point names' proposed are :
  • Contrat Pro Data Illimité / a2bouygtel.com
  • B2Bouygtel / b2bouygtel.com
  • Forfait Data / ebouygtel.com
The last is the usual 'Acces point name', for Internet.
But for send or receive some SMS, I've added :
  • Bouygesmms / mmsbouygtel.com
As example, with 'Forfait Data ' with 'nmcli' :
cdc-wdm0: connecté à Forfait Data
    "cdc-wdm0"
    gsm (qmi_wwan, option1), hw, iface wwan0, mtu 1500
    ip6 par défaut
With my definition for MMS :
cdc-wdm0: connecté à Bouyguesmms
        "cdc-wdm0"
        ip6 par défaut
So you have right to recommend only one word for define the 'Access point name', it's simpler to use in a script.
RE: Howto - automatically recover your modem and mobile data after deep sleep - by Gribouille - 12-04-2020, 04:36 AM
  Mobile internet via cellular network mostly not working Anna 18 10,377 01-19-2024, 02:59 AM
Last Post: anonymous
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,877 06-06-2023, 06:36 AM
Last Post: freelectro
  4G data on default startup / boot dcinoz 1 850 04-29-2023, 11:24 PM
Last Post: dcinoz
  ModemManager debug mode? (Needed to flash modem) calinb 1 1,222 02-27-2023, 04:18 PM
Last Post: calinb
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,593 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,396 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,574 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 17,102 10-29-2022, 09:16 AM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 4,848 09-23-2022, 05:15 AM
  no wakeup from deep-sleep jsch 8 4,136 09-05-2022, 03:03 AM
Last Post: jsch
