FydeOS for You - Pinebook Pro
#53
FydeOS 14.1: Bypass the TF card to burn Fydeos os, directly decompress the xz image on the armbian for pinebook pro system, and then use the dd command to directly install it on the emmc. Shut down, unplug the card, and restart successfully
FydeOS for You - Pinebook Pro - by also1412 - 11-17-2020, 08:56 PM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 11-18-2020, 04:54 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-18-2020, 09:30 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 11-18-2020, 09:34 AM
RE: FydeOS for You - Pinebook Pro - by clover - 11-18-2020, 10:05 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-18-2020, 03:01 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-18-2020, 10:24 PM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-19-2020, 08:12 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-19-2020, 08:45 AM
RE: FydeOS for You - Pinebook Pro - by clover - 11-19-2020, 02:21 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-19-2020, 09:26 PM
RE: FydeOS for You - Pinebook Pro - by wove - 11-24-2020, 07:17 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-24-2020, 09:41 AM
RE: FydeOS for You - Pinebook Pro - by wove - 11-24-2020, 12:00 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-06-2021, 04:52 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-07-2021, 08:15 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-08-2021, 02:47 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 07:51 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-12-2021, 09:52 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 10:35 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-12-2021, 06:54 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 03-06-2021, 02:27 AM
FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 06:55 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 05:26 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-19-2021, 07:57 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 09:09 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-19-2021, 12:33 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 07:10 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 09:49 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 09:53 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 11:17 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-20-2021, 07:17 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-20-2021, 11:16 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-20-2021, 12:26 PM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-20-2021, 05:03 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-20-2021, 04:37 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-26-2021, 11:24 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-21-2021, 12:01 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 02-23-2021, 03:02 AM
RE: FydeOS for You - Pinebook Pro - by ImmyChan - 03-25-2021, 12:23 PM
RE: FydeOS for You - Pinebook Pro - by Mangled - 11-14-2021, 03:36 PM
RE: FydeOS for You - Pinebook Pro - by Mangled - 01-09-2022, 03:31 PM
RE: FydeOS for You - Pinebook Pro - by wangyukunshan - 12-19-2022, 07:42 PM
  Which OS can I actually run a 1080p pinebook non-pro? Scott104 1 3,572 10-09-2021, 02:47 PM
Last Post: TRS-80
Question FydeOS privacy policy? TDC_PBP 1 3,809 09-07-2021, 06:14 AM
Last Post: ImmyChan
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 4,277 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 13,492 06-22-2020, 06:23 AM
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 7,941 12-07-2019, 02:33 PM
Last Post: TDC_PBP
