General getting started
You should be able to boot from SD, then mount the eMMC and look around on it to see if it's blank.  Something like
mount /dev/mmcblk1p2 /mnt
in some terminal emulator, then look in /mnt.  Remember to umount /mnt after.
Not to discourage you but there's a big learning curve and learning from mistakes is how I often do it.  If there's nothing on the eMMC you should be able to download an image and write it to eMMC.  I still use the mrfixit Stretch.  Something like
dd if=yourfile.img of=/dev/mmcblk1 bs=1M status=progress
when it finishes shut down and take out the SD.  It should boot from the eMMC.  Username and password are both rock I think.
If there's anything on the eMMC you want to save, copy it off to the SD while you have it mounted before you overwrite it with the image.
General getting started - by James Good - 11-13-2020, 01:14 PM
RE: General getting started - by wdt - 11-13-2020, 02:48 PM
RE: General getting started - by James Good - 11-13-2020, 03:06 PM
RE: General getting started - by motezart - 11-17-2020, 08:28 AM
RE: General getting started - by James Good - 12-13-2020, 01:17 PM
RE: General getting started - by wdt - 11-13-2020, 03:22 PM
RE: General getting started - by James Good - 11-15-2020, 06:36 PM
RE: General getting started - by wdt - 11-15-2020, 07:37 PM
RE: General getting started - by James Good - 11-16-2020, 11:30 AM
RE: General getting started - by wdt - 11-16-2020, 01:27 PM
RE: General getting started - by ab1jx - 11-16-2020, 10:33 PM
  NixOS getting started guide _hg_ 4 7,749 07-06-2020, 08:02 PM
Last Post: _hg_
