emmc vs NVMe real-world performances
I have an NVMe drive but I'm not entirely convinced that it is ideal, there are a number of problems:
  1. The drive uses some power, and even though I selected the drive with very low wattage and good power control options, it's taken maybe 2 hours off the battery capacity.
  2. Getting the OS to boot from the drive can be a nightmare and you can get an unbootable system after an update etc. depending on your setup. Order the serial cable as well when you order the adapter.
  3. If I limit the power to something that doesn't eat the battery immediately, the performance is not orders of magnitude faster.
There are of course benefits:
  1. Can be much faster in sequential read and random read.
  2. Can be very much larger than the eMMC
  3. Since the drive is big you can use a real swap partition.
  4. Compilation can really use a faster drive, too, it is after all loading a lot of small files and some programs (especially C++) need a lot of RAM to compile which means swap may be necessary.
Anyway, I'm using the WD Blue SN550 250GB and so far I'm quite happy with it, the power management is quite good on it. I have it set on power level 2 at boot.
emmc vs NVMe real-world performances - by Henry - 11-11-2020, 04:23 PM
RE: emmc vs NVMe real-world performances - by slyecho - 11-14-2020, 06:45 PM
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 622 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 884 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 2,952 10-23-2025, 09:38 AM
Last Post: jceaser
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 92,893 11-20-2023, 06:22 PM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 2,212 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 2,469 07-13-2023, 01:50 PM
Last Post: PaulQ
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 5,012 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 4,257 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 4,387 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 9,404 02-06-2023, 09:11 AM
