Powering off & won't power back on w/o battery disconnect
>Unfortunately Suspend or Hibernate just seem to power the system off,,,, this is settings
Hibernate does not work,, you may be lucky and have lid magnet in "right " place
Lots are wrong, turns off when 1" from closed, and then, when closed, turns on
check dmesg for sleep,,, dmesg |grep suspend OR dmesg |grep s2idle,,the 1st FAR better(~7%/d)
/etc/systemd/sleep.conf,, ,, SuspendState=mem
sometimes nothing will wake it up (other distros), for me, kde, systemsettings5, pwr button ->ask
And pwr button wakes it, nearly everything else is off
BTW, kernel 5.9 locks (won't wake), I had to downgrade (5.8.14)
RE: Powering off & won't power back on w/o battery disconnect - by wdt - 11-10-2020, 08:42 PM
  Lithium Battery Connector Franestra 0 119 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 324 03-13-2024, 10:46 AM
Last Post: u974615
  Bad replacement battery? chris88233 3 367 02-19-2024, 04:59 PM
  Bypassing the Battery gilwood 0 231 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 549 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 1,063 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,872 09-26-2023, 01:08 AM
Last Post: david-lechner
  Battery drain when off srs5694 1 1,013 03-24-2023, 06:05 PM
  Increasing the maximum power draw dsimic 15 19,452 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,883 11-13-2022, 06:10 PM
Last Post: pineymousepad
