Powering off & won't power back on w/o battery disconnect
Question
Hello Pine64 forums.
So this is a strange one to me, but only for the frequency of occurrence - which I'll need to explain.
When using my Pinebook Pro, Manjaro 20.04 Cinnamon DE, it will seemingly power off & simply stay off when it goes to sleep/hibernate. This even occurs, eventually, when no sleep mode is enabled. That is to say: it will power off & won't power back on until I pull off the bottom cover, disconnect the battery connect from the mainboard, press the power button for 5 seconds or so, and reconnect the battery (or power cord - so long as it's getting power).
In my prior years as a desktop support tech I ran across many laptops where the mainboard's little capacitors would not regulate power to the system. Pulling the battery connector out, pressing the power button for 5 seconds or so to discharge the capacitors (I presume), and powering it back on (via battery or AC adapter) gets it working again. But I have to do this so frequently of late I'm starting to wonder if it's an OS issue. It doesn't seem to matter which governor I set via the cpupower utility (I will state I typically run it on the "performance" governor on AC power).
Has anyone got any ideas as to what's going or what else I can try to troubleshoot it?
Thanks a ton!
Powering off & won't power back on w/o battery disconnect - by jimsurvak - 11-06-2020, 08:53 PM
  Lithium Battery Connector Franestra 0 120 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 327 03-13-2024, 10:46 AM
Last Post: u974615
  Bad replacement battery? chris88233 3 376 02-19-2024, 04:59 PM
  Bypassing the Battery gilwood 0 236 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 560 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 1,073 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,875 09-26-2023, 01:08 AM
Last Post: david-lechner
  Battery drain when off srs5694 1 1,018 03-24-2023, 06:05 PM
  Increasing the maximum power draw dsimic 15 19,521 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,922 11-13-2022, 06:10 PM
Last Post: pineymousepad
