Axolotl on PinePhone / Mobian
#67
(03-19-2021, 06:10 AM)Anna Wrote:
(03-19-2021, 03:56 AM)arno_nuehm Wrote: there are still some bugs in v0.9.9, which make it sometimes hard to add contacts and link signal desktop.
have you tried to use the server/browser setup? with firefox, it is possible to link signal desktop and adding contacts, too. that workaround did it for me.
and fyi: i will definitely provide a new deb-package, when the next version is out - this time hopefully more "debian-like".
have a nice day!
Thank you, @arno_nuehm ! Looking forward to the next version then.
Well, I installed Axolotl with a completely fresh mobian installation, but I still cannot add contacts or devices.
Where can I find more info about linking firefox with the signal desktop? Tried to figure it out, but failed.
How do you paste by the way, does that work on your phone, @Pelecanus ? (I have to attach a keyboard an use STRG V).
--> pasting: i'm switching to the squeekboard terminal keyboard (tap on the globe) and press strg+v - that should work.
--> contacts: that should work with the actual version, the bug was closed with 0.9.9... seems weird, that it doesn't in your case. i just tested it...
--> signal desktop: try to use the daemonized server setup with the two other desktop files, which came with the deb file (axolotl-server.desktop and axolotl-browser.desktop in /usr/share/applications) - in firefox, the linking worked for me nicely.
EDIT: from the mobian-dev telegram group: "Here I sometimes had to close the app and reopen for the app to show imported contacts. You can also check `./config/textsecure.nanuc/registeredContacts.yml`to see if they did get added there." - maybe that's the same for you, when adding new contacts.
Axolotl on PinePhone / Mobian - by arno_nuehm - 11-06-2020, 11:24 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-06-2020, 04:46 PM
RE: Axolotl on PinePhone / Mobian - by User 18618 - 11-11-2020, 04:25 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-16-2020, 07:05 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-16-2020, 10:32 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2020, 11:51 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-18-2020, 02:38 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2020, 01:49 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 12-07-2020, 03:03 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-07-2020, 04:20 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 12-07-2020, 05:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-07-2020, 05:54 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-16-2020, 07:06 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-19-2021, 04:16 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-25-2021, 05:17 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-26-2021, 03:25 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-28-2021, 05:47 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-29-2021, 07:39 AM
RE: Axolotl on PinePhone / Mobian - by acm006 - 12-21-2020, 02:00 PM
RE: Axolotl on PinePhone / Mobian - by Ersatz - 12-21-2020, 08:38 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-22-2020, 04:59 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 08:48 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 12:11 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 02:32 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-02-2021, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-03-2021, 03:27 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-04-2021, 04:05 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-04-2021, 04:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-05-2021, 04:51 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 03:29 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 03:54 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 04:05 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 08:48 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 11:01 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 03:58 PM
RE: Axolotl on PinePhone / Mobian - by RTP - 02-11-2021, 04:35 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-12-2021, 04:35 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 02-13-2021, 03:11 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-13-2021, 05:47 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-13-2021, 08:04 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-25-2021, 06:22 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 02-25-2021, 09:16 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-27-2021, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 03-06-2021, 02:51 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-06-2021, 04:56 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-09-2021, 04:25 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-09-2021, 05:51 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-17-2021, 02:31 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-17-2021, 03:15 PM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-18-2021, 06:46 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-18-2021, 11:07 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-18-2021, 12:30 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-18-2021, 02:12 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-19-2021, 03:56 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-19-2021, 06:10 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-19-2021, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-19-2021, 06:32 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-19-2021, 08:42 AM
RE: Axolotl on PinePhone / Mobian - by RTP - 03-15-2021, 03:54 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-19-2021, 10:21 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-05-2021, 12:48 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-13-2021, 05:59 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 12:42 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 01:45 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 02:26 PM
One single contact broken in Axolotl - by Anna - 05-06-2021, 04:08 AM
RE: Axolotl on PinePhone / Mobian - by Avatars - 05-10-2021, 07:07 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 05-13-2021, 05:38 AM
RE: Axolotl on PinePhone / Mobian - by Avatars - 05-13-2021, 05:42 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 05-14-2021, 05:50 AM
RE: Axolotl on PinePhone / Mobian - by richieeee - 05-20-2021, 01:31 PM
RE: Axolotl on PinePhone / Mobian - by Cree - 05-20-2021, 12:30 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 05-28-2021, 07:52 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-02-2021, 12:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 06-02-2021, 05:42 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-03-2021, 03:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 06-03-2021, 11:06 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 06-11-2021, 07:16 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-23-2021, 08:13 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-06-2021, 02:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-12-2021, 01:46 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-10-2021, 05:19 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-20-2021, 02:09 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 07-20-2021, 01:34 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-21-2021, 02:39 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 07-21-2021, 02:35 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-23-2021, 12:32 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-27-2021, 06:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-28-2021, 05:23 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-28-2021, 07:55 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-04-2021, 07:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-06-2021, 02:29 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-16-2021, 08:22 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 09-16-2021, 11:15 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 09-16-2021, 02:19 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 09-17-2021, 01:21 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-17-2021, 02:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-26-2021, 10:21 AM
RE: Axolotl on PinePhone / Mobian - by juju - 09-26-2021, 07:12 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-27-2021, 01:58 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 09-30-2021, 04:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-21-2021, 01:24 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 10-21-2021, 01:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-28-2021, 09:44 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-04-2021, 02:02 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-17-2021, 10:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2021, 10:38 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-17-2021, 02:14 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2021, 03:02 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-19-2021, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-23-2021, 02:43 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-24-2021, 11:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-24-2021, 11:48 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-24-2021, 02:46 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-23-2021, 09:34 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-29-2021, 07:34 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 11-29-2021, 10:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-29-2021, 11:56 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-30-2021, 03:47 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-02-2021, 03:09 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-03-2021, 04:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2021, 11:29 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-06-2021, 12:00 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2021, 12:48 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-12-2021, 02:46 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-12-2021, 12:57 PM
RE: Axolotl on PinePhone / Mobian - by ichbins - 12-16-2021, 01:14 PM
RE: Axolotl on PinePhone / Mobian - by eFqLLnGo - 12-17-2021, 05:25 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-20-2022, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by DominiqueM - 01-20-2022, 08:06 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-21-2022, 04:45 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2022, 01:05 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-13-2022, 04:33 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 02-16-2022, 04:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-16-2022, 04:41 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 03-15-2022, 05:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-17-2022, 03:41 AM
RE: Axolotl on PinePhone / Mobian - by user641 - 03-17-2022, 04:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-17-2022, 11:43 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-04-2022, 07:43 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-04-2022, 09:03 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-05-2022, 05:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-05-2022, 06:30 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-14-2022, 03:16 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-09-2022, 02:10 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 08-11-2022, 02:28 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-15-2022, 11:26 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-19-2022, 01:33 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 08-20-2022, 07:47 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-23-2022, 04:17 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 08-23-2022, 09:37 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-04-2022, 06:50 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-04-2022, 07:10 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 09-04-2022, 11:41 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-05-2022, 11:00 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-05-2022, 02:24 PM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-05-2022, 12:55 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-06-2022, 12:33 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-06-2022, 01:00 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-08-2022, 05:24 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-11-2022, 05:35 PM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-12-2022, 02:55 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-17-2022, 09:01 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 10-27-2022, 01:51 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-27-2022, 03:31 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 10-28-2022, 05:17 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 10-29-2022, 09:16 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-31-2022, 04:56 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 11-01-2022, 05:22 AM
RE: Axolotl on PinePhone / Mobian - by benedikt55 - 11-01-2022, 08:10 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-01-2022, 04:02 PM
RE: Axolotl on PinePhone / Mobian - by Eugo - 11-02-2022, 08:43 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-08-2022, 09:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-08-2022, 03:08 PM
RE: Axolotl on PinePhone / Mobian - by benedikt55 - 11-09-2022, 04:02 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-10-2022, 02:12 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-10-2022, 02:40 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-23-2023, 03:46 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-24-2023, 02:07 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-27-2023, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-27-2023, 04:38 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-27-2023, 04:52 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 01-27-2023, 07:06 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-27-2023, 06:08 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-29-2023, 10:52 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 02-07-2023, 02:19 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 03-13-2023, 09:14 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-22-2023, 12:05 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 03-22-2023, 04:17 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-22-2023, 04:58 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 03-22-2023, 10:48 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-26-2023, 01:49 AM
RE: Axolotl on PinePhone / Mobian - by anonymous - 06-18-2025, 02:22 PM
RE: Axolotl on PinePhone / Mobian - by anonymous - 06-25-2025, 01:19 PM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 06-19-2025, 01:52 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,741 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,764 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,765 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  VoIP account on mobian dialer j_s 0 1,905 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,953 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
