Batteries without thermostat
(05-28-2016, 11:12 PM)MrWizerd Wrote: I have a two wire battery and I tried connecting it to the board on pin one and the but it seems not to work.  According to the silk screen, and schematic that is correct. The schematic has a note however that I don't understand
 "If do not use temp. Measure feature. Place OR."  I am not sure what this means or what OR  Is referring to, seems that I need to do something but I'm not sure what... Any ideas?
The middle wire connects to temperature sensor (termistor) that located in close or middle of lithium battery pack, this allows the Pine A64 board to cut off charging power if discover battery temperature raise up. If using temperature measurement feature but no termistor in place situation, then need to place a 10K resistor.
Batteries without thermostat - by MrWizerd - 05-28-2016, 11:12 PM
RE: Batteries without thermostat - by tllim - 05-28-2016, 11:50 PM
RE: Batteries without thermostat - by MrWizerd - 05-29-2016, 01:30 AM
RE: Batteries without thermostat - by tllim - 05-29-2016, 09:20 AM
RE: Batteries without thermostat - by sarav_sara - 06-04-2019, 06:06 AM
  Using tablet displays and batteries janeku 4 8,663 06-10-2016, 01:13 AM
