What works. What doesn't work.
#21
(11-12-2020, 11:17 AM)sfb Wrote:
(11-12-2020, 01:09 AM)liewyec Wrote: Hello, I have the Manjaro edition pinephone and I flashed SD card with sailfish OS, but I can't unlock sim card. It is detected, but when i try to unlock it in settings I can see dialog asking for pin but when i try to confirm pin it does nothing. I have same problem with telegram, I insert login code and than nothing is happening. Does someone has any idea how to fix ti?
Sorry for the stupid question but you did accept your input by swiping?
No i used button in bottom right corner of the keyboard. It is possible to accept by swiping?
RE: What works. What doesn't work. - by LinAdmin2 - 11-03-2020, 11:47 AM
RE: What works. What doesn't work. - by josekar - 11-04-2020, 04:46 PM
RE: What works. What doesn't work. - by stemplet - 11-06-2020, 01:14 PM
RE: What works. What doesn't work. - by clover - 11-08-2020, 04:56 PM
RE: What works. What doesn't work. - by W64 - 11-09-2020, 10:36 AM
RE: What works. What doesn't work. - by stemplet - 11-09-2020, 05:02 PM
RE: What works. What doesn't work. - by W64 - 11-09-2020, 05:20 PM
RE: What works. What doesn't work. - by stemplet - 11-09-2020, 07:14 PM
RE: What works. What doesn't work. - by W64 - 11-09-2020, 08:11 PM
RE: What works. What doesn't work. - by clover - 11-11-2020, 12:02 AM
RE: What works. What doesn't work. - by as400 - 11-11-2020, 03:28 AM
RE: What works. What doesn't work. - by stemplet - 11-11-2020, 09:42 AM
RE: What works. What doesn't work. - by liewyec - 11-12-2020, 01:09 AM
RE: What works. What doesn't work. - by sfb - 11-12-2020, 11:17 AM
RE: What works. What doesn't work. - by liewyec - 11-12-2020, 12:57 PM
RE: What works. What doesn't work. - by LinAdmin2 - 11-12-2020, 01:10 PM
RE: What works. What doesn't work. - by liewyec - 11-12-2020, 01:30 PM
RE: What works. What doesn't work. - by LinAdmin2 - 11-13-2020, 11:32 AM
RE: What works. What doesn't work. - by liewyec - 11-13-2020, 12:36 PM
RE: What works. What doesn't work. - by liewyec - 11-18-2020, 02:01 AM
  When mobile data works calls don't with Sailfish OS albafrati 0 2,268 06-25-2024, 09:28 AM
Last Post: albafrati
