PSA: Transition in progress - don't update !
#20
(11-03-2020, 03:39 AM)a-wai Wrote: ...
It is recommended that you don't update your system for a few days
An update running 20201104 nightly.
1) My earlier fear about not waking from CRUST was unfounded (the first time I had a problem, since then I have had no problems)
2) Not sure where scale-to-fit was on earlier nightlies - seems to be not enacted from 20201104
gsettings set sm.puri.phoc scale-to-fit true
works fine though.
3) apt upgrade works OK, as you would expect apt dist-upgrade creates a mess that is beyond my skills to tidy!!
4) What is the package name of the Software application? I really want to remove it as I prefer controlling (or ruining!) my life with apt and find its efforts to sanitise things irksome.
5) Getting a lot of
[34795.577181] anx7688 1-0028:   soft = 0x01
[34795.580805] anx7688 1-0028: recv ocm message cmd=242 01 f2 0d
[34800.589842] anx7688 1-0028: status irq
[34800.595559] anx7688 1-0028:   soft = 0x01
[34800.599261] anx7688 1-0028: recv ocm message cmd=242 01 f2 0d
[34810.052607] anx7688 1-0028: status irq
[34810.056640] anx7688 1-0028:   soft = 0x01
[34810.060307] anx7688 1-0028: recv ocm message cmd=242 01 f2 0d
[34815.069685] anx7688 1-0028: status irq
[34815.075057] anx7688 1-0028:   soft = 0x01
[34815.078707] anx7688 1-0028: recv ocm message cmd=242 01 f2 0d
in dmesg: seems to be related to my dumb wallwart charger, possibly after the battery is fully charged?
6) A feeling in my waters that I cannot measure: previously I had Mobian on eMMC, at the moment it is running from and SDcard (Evo+). My waters say phosh crashes more often when running from an SDcard, i.e. it has some kind of I/O timing problem?
Otherwise at least as good as before, and I do feel smug about having 5.9 even though I stumbled in early because of my dumbness!
RE: PSA: Transition in progress - don't update ! - by dukla2000 - 11-06-2020, 05:20 AM
  trixie update poll questions suggestions j_s 5 467 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 15,352 12-04-2024, 07:01 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 11,694 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 10,299 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 11,919 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 3,998 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 10,411 09-05-2022, 12:10 AM
  Loving latest Mobian Update drh 11 10,972 08-22-2022, 12:19 PM
