How easy is it to add donor keyboard and trackpad?
I mean if I happen to find ones that fit size-wise? Do they use standard connectors? Will it work plug and play or some basic mapping? Or will it require making difficult changes to more low level stuff like the bios?
RE: How easy is it to add donor keyboard and trackpad? - by ENV - 11-11-2020, 10:23 AM
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 243 02-17-2024, 07:06 PM
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,017 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 686 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,102 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,655 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 6,421 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 1,318 11-29-2021, 01:55 PM
Last Post: stozi
  pinebook pro trackpad randomly stops working chewie 5 5,805 08-10-2021, 04:33 PM
Last Post: chewie
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,814 08-09-2021, 09:20 PM
  Some keyboard keys not working oddsocks 10 10,718 04-20-2021, 08:33 AM
Last Post: dsimic
